Old 07-20-2012, 09:17 AM   #11
Liked 1,909 Times in 427 Posts
Default Re: Rocker Arm Ratio
They can, and will, check lift at the valve, and then lift at the cam. From that they will check rocker arm ratio. If the ratio is greater than what is in the blueprint specs, they will throw you out.
Feel free to ask Travis Miller, or Dave Ley about this, they will explain it to you. There are also several threads on the subject that explain why and how about rocker ratio. I have seen people thrown out for rocker ratio.
Old 07-20-2012, 11:41 PM   #12
Marine One
Marine One's Avatar
Rocker ratio is not constant in the swing of the arc. Check max lift at the valve and at the cam all you want and you will never catch it that way, unless you went crazy and tried to go from something like 1.6 to 1.8
Chad Sheets | STK 319 | 10.69 | 1.39
Marine One is offline   Reply With Quote
Old 07-21-2012, 03:06 AM   #13
RULER
Liked 58 Times in 18 Posts
Exclamation Re: Rocker Arm Ratio
If they check lobe lift and x it by the correct ratio it better be the same or damn close to what it checks at the valve, you will always loose some from spring pressure but not the difference between 1.5 and 1.6, but when was the last time they checked lobe lift ? and is that something there doing now ?
RULER is offline   Reply With Quote
Old 08-03-2012, 03:57 PM   #14
Charley Downing
Liked 653 Times in 89 Posts
As per Danny and Bruce at Chicago nationals this year any ratio is allowed.
Dalles Glens corvette had 1.55 rockers from comp cams on his lt1 corvette and 1.5 is the spec .Danny told me all NHRA cares about is that the cam checks
And that is fact.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 08-03-2012, 04:22 PM   #15
PJ305
Liked 5 Times in 4 Posts
Charley,
Wade O. said Travis checked all the rocker ratio's at Chicago so how could Dallas Glenn be legal with 1.55 rockers when 1.50 are in the blueprint spec.
Travis can you clear this up for the guys going to Indy.
Thanks
PJ305 is offline   Reply With Quote
Old 08-03-2012, 04:29 PM   #16
Originally Posted by PJ305 View Post
Charley,
Thanks
Get it in writing from Glendora. Email them, and then follow up with a phone call.
Old 08-03-2012, 04:41 PM   #17
PJ305
Alan,
You can use a letter from Glendora for toilet paper. I spent $1000 for a Pontiac carb for my Chevy and have a letter that it's legal but I can't run it. I have another letter from Glendora that says angle adapters for spark plugs are legal and wasted $500 and there not legal.
Old 08-03-2012, 04:51 PM   #18
Alan,
It holds up a little better than their word, or second hand information.
I'm betting Travis will not post any clarification, as NHRA won't want him to. Not to mention they may over rule him on a whim. Which is one of the reasons Wesley Roberson has completely quit.
Old 08-03-2012, 05:21 PM   #19
PJ305
Thanks Alan, I will roll the dice at Indy and if I get thrown out at tear down I will be just another cheater.
Old 08-03-2012, 05:50 PM   #20
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
And folks wonder why people just stop racing, the rules are still not the same across the board. Alan, you are right even tech directors are at a loss when Danny is around.
Bob Pagano A/SA
