Old 07-22-2012, 06:55 PM   #1
Jim Carter
Liked 19 Times in 3 Posts
Smile AFCO A_Frame Bushings
I am looking into buying a set of AFCO all steel A-frame bushings and noticed the Jegs catalog has a part number for a light weight version for the lowers. Can anyone tell me how much lighter the" light weight" versions are over the standard? Is it worth the extra cost? The car is a 1968 Chevelle stocker with an all steel big block. Any explanation on how weight reduction was achieved?
Jim Carter is offline   Reply With Quote
Old 07-22-2012, 07:12 PM   #2
R. Thorne
Liked 101 Times in 34 Posts
Default Re: AFCO A_Frame Bushings
I believe you will find a plastic style bushing (similar to del-a-lum) in those as compared to their "standard" solid steel type. They would be considerably lighter, of course, but not as light as delalum. Ron.
R. Thorne is offline   Reply With Quote
Old 07-22-2012, 07:18 PM   #3
cad
cad's Avatar
Liked 93 Times in 52 Posts
Jim, I have a set for my camaro that have not been installed, yet. I received the standard ones by mistake, so I can tell you that they are almost half the weight. I was shocked how heavy the standard ones were.
I got them off ebay from a seller for $139 for the whole kit. They are not Afco, but they are identical, as I believe the dirt track cars use them, also.
I havent installed as I may go with Global West's kit.
Clark
