Old 07-23-2012, 12:07 AM   #1
Al Loyrat
Default 2013 Cobra Jet 427
Could this be a 4.125 X 4.00 SBF ?
Al Loyrat is offline   Reply With Quote
Old 07-23-2012, 08:58 AM   #2
BlueOval Ralph
Banned
Default Re: 2013 Cobra Jet 427
Sounds right based on 351 W block
BlueOval Ralph is offline   Reply With Quote
Old 07-24-2012, 02:16 AM   #3
Tom P
Liked 239 Times in 94 Posts
Isn't that what the 428 Windsor is now?
Old 07-24-2012, 04:05 AM   #4
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Yes, 4.125x4.000
4.080X4.100 for the 428.
kdanner is offline   Reply With Quote
Old 07-24-2012, 08:09 AM   #5
Ed Wright
Ed Wright's Avatar
Is it rated at 275 HP?
Ed Wright 4156 SS/JA
Old 07-24-2012, 01:55 PM   #6
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
425 HP, same as the COPO Camaro. Same bore and stroke, the Ford has a longer rod. Wish I had either. Dyno
Old 07-24-2012, 03:11 PM   #7
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I was comparing the 2010 352 @ 285 hp vs. the 2013 363 @ 330 hp for the SS/GT classes.
The 2010 has a bore/stroke of 4.060 x 3.400
The 2013 has a bore/stoke of 4.125 x 3.400.
Everything else looks the same.
Using the .070 allowed overbore rule, a 2013 looks like it could also run as a 2010.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-24-2012, 05:04 PM   #8
BlueOval Ralph
Banned
Taking a 4.125 and a .060 over bore per the rule give you a 4.185 bore with a bore spacing of 4.380 this only leaves less than .200 between bores not a lot material for head gasket seal.
Old 07-25-2012, 10:39 AM   #9
rawhide
Liked 7 Times in 5 Posts
I wish I had a longer rod to.
rawhide
rawhide is offline   Reply With Quote
Old 07-25-2012, 09:47 PM   #10
Al Loyrat
The 327 COPO has over a 2 to 1 rod ratio.
