Old 08-01-2012, 11:44 AM   #1
steve4speednova
Default dart big m block
anything i need to know about useing a dart big m block for stock eliminator 396/375. i know the lifter bores are .300 tall. do they need to be mark iv.style ? thanks steve
steve4speednova is offline   Reply With Quote
Old 08-01-2012, 01:59 PM   #2
Default Re: dart big m block
First off, make sure you get a 396 block, it carries a special part number, and is a special order piece.
If you're running in Stock Eliminator, you'll be using some form of flat tappet "mechanical" lifter. The 0.300" taller boss does not matter. None of my suppliers makes a 0.300" taller lifter that I am aware of, nor have I seen the need. There should be no problem with pushrod clearance, but check it anyway.
It will require full preparation, just like a GM block. You should have the dimensions checked, though it will likely not require blueprinting of the lifter bore or cylinder bore location. It probably will require the main bores to be lightly honed for size, and it will almost certainly require decking (make sure it is square, it probably will be, and that whoever does it keeps it that way).
The shop that preps it better know exactly what they are doing with a Dart block, from experience, or the rings will never seat, you'll have blow by and oil consumption problems. I see that happen a lot.
Old 08-01-2012, 02:05 PM   #3
Arnold Greene
Liked 3 Times in 2 Posts
You will most likely need to change the front springs. The Dart 396 block weighs 290 pounds! Ask me how I know.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
Old 08-01-2012, 03:11 PM   #4
steve4speednova
thanks guys for the reply. I,m useing 1965 #962 block now, with 4.150 bore. it makes about 560 hp.to the rear wheels. what would the dart block be worth in power ?
Old 08-01-2012, 03:34 PM   #5
richie 2
Liked 205 Times in 93 Posts
are they gaining any poularity for SS applications?
Old 08-01-2012, 04:34 PM   #6
Could be worth a little. Depends on how well your current block is blueprinted, how sound it is, and how well the Dart block gets finished. If you're putting all new parts in it, and you have the right sources, you might pick up power there, depending on how old your current stuff is.
Old 08-02-2012, 07:28 AM   #7
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
560 at the tires? Why would you change anything on that 396, thats amazing!
Pedigo Perf is offline   Reply With Quote
Old 08-02-2012, 10:44 AM   #8
carl hinkson
Liked 18 Times in 10 Posts
I CNC machine alot of Dart big -M blocks and this is what useally needs to be addressed.
Some block notes:
I deck all of them to a finished number depending on gasket & desired piston height
Block needs to be honed with a plate or bored & honed depending on bore
Bottoms of bores need to be chamfered
Most need the lifter bores honed, at the least checked
Most need line honing
All pipe threads need to be retapped
Oil return from fuel pump cavity needs to be done
Core plug holes need deburing
CHECK THAT THE DISTRIBUTOR GEAR DOES NOT CONTACT THE BLOCK BY THE CAM.
carl hinkson is offline   Reply With Quote
