Old 07-05-2012, 04:52 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question 2000 c3500 2wd dually.....front tires
This truck has 70,000 miles on it, used for towing only.......second set of E range Uniroyals....tires are cupping,sometimes refered to by tire people as "scalloping" but not on the edges, occurs at different places 2nd or 3rd tread over from edge it just "scoops" out like someone dug into it with a spoon at several locations, looks wierd. Front end lined up several times, could this be a shock problem----what brand-model of shock do you recommend ???
Rusty Davenport is offline   Reply With Quote
Old 07-05-2012, 05:59 PM   #2
Greg Hill
Liked 279 Times in 68 Posts
Default Re: 2000 c3500 2wd dually.....front tires
I put some Monroe HD gas shocks on my truck and it made a big difference in handling. My truck is a 2001 gmc 3500 2 wd.
Greg Hill 4171 STK
Old 07-06-2012, 05:53 AM   #3
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Rusty in the past I've spoken with consultants at GM technical assistance about this concern, they always have said frequent tire rotations. They suggest at 5,000 mile intervals.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 07-06-2012, 09:25 AM   #4
tj310
Is this the HD straight axle chassis ? I just bought a used truck of the same vintage with the 19.5 tires . I was amazed how well it rides with tires like that. I figured that it was just the cheap tires.---Trevor
Old 08-01-2012, 06:02 PM   #5
Jim Whitehead
Liked 150 Times in 41 Posts
Very common problem on the Uniroyals.
Jim Whitehead is offline   Reply With Quote
Old 08-02-2012, 12:36 PM   #6
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
Sounds like two problems, not enough rotations and worn shocks! SAE came out a few years ago and said that OEM shocks are done at 50k...
"Go With Confidence"
Tommy Gaynor is offline   Reply With Quote
Old 08-04-2012, 07:25 AM   #7
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Check the front in height, is it sticking up in the air when you have the trailor hooked to it and loaded? If it is it very well could be your problem...You towing a fifth wheel or tag?
FrankChastain is offline   Reply With Quote
Old 08-06-2012, 10:27 AM   #8
Rusty Davenport
towing a 28ft tag and a heavy one at that.............
NHRA AND IHRA STOCK ELIMINATOR 2772
