Old 08-03-2012, 12:07 AM   #11
David Lee
Liked 346 Times in 126 Posts
Default Re: Inline six/fox body header?
If I were you I would just go bracket race that combo and have fun with it. Do all the suspension mods etc and then drop the 302 in it. Spending the money on a header that may or may not work well is just a waste of money.
Old 08-03-2012, 03:38 AM   #12
VStock
Originally Posted by iraceitall View Post
It's a combo I have, what I have accumulated has been dirt-cheap (trying my hand at a Dime Rocket) and the NHRA HP is wrong (working on that). I'm going to start with the six, and maybe move to a 302 later. I'm following some good advice from Billy Nees, and honestly, I'm a glutton and like the challenge. I have always liked messing with sixes, and oddballs at that.
You're facing the same issues I am. I have a car/engine combo I want to run (67 El Camino/230), but the advice here is that it's not competitive. Do I build what I have and want to build, or do I buy a car that has a better chance of winning?
Marty Knox
VStock is offline   Reply With Quote
Old 08-03-2012, 03:46 AM   #13
David Lee
You can win with any car,just talk to Lane Weber or a host of other guys here like Mark Y. The problem is you may spend more money than necessary jsu to get this combo run the number
Old 08-03-2012, 05:40 AM   #14
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Just make sure this combo has the potential to at least run the index if you are going class racing. Other wise it's just a waste of time and money.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-03-2012, 11:40 AM   #15
Joe Toller
Liked 9 Times in 9 Posts
This engine combo can run the index in a Maverick or Comet, I get a slightly better flowing head and a little less weight, so I figure if I'm in the ballpark I *should* at least run the index. I personally think it'd be fun as hell to put a 200 with a 1bbl in the 15's. I like the oddballs. At this point, I have everything but a converter and cam, and by scrounging (thank you CL and ebay) and using some used parts I am in it $1500. Granted that is just collecting parts and I have yet to tear into the motor and trans. I found a header unused for $150. I'll probably start a build blog to share, good or bad.
When someone says why, ask, why not?
Old 08-03-2012, 12:30 PM   #16
Joe Toller
If it doesn't run the number, I can put that 200 in another Fairmont with some more cam and carb on the street and then I'll go 302, but not until after I give the six a fair shot.
Old 08-07-2012, 06:54 PM   #17
Capri
Liked 27 Times in 14 Posts
Cool Re: Inline six/fox body header?
My car is not that competitive. I am a 1 of 1 combination. Im usually .3 back of the chebbie guys and V6 other chebbie and pontiac guys. I have a blast, do ok, and did better than was expected first time around when the car was built. Go for it. I seem to recall a rather good running straight 6 in a Comet........... with a stick........
AD
Capri is offline   Reply With Quote
Old 08-12-2012, 11:36 PM   #18
Joe Toller
What are you running Capri?
