I've had the autometer playback II tach with the driveshaft sensor for the last 3 years and a few races ago i lost the magnets going downtrack. I just bought the racepak collar with the magnets embedded so I wouldnt have to mess around with the autometer way of JB welding magnets into the driveshaft . However, autometer sensor requires the south side of the magnet to face up and the racepak magnets have north side facing up so I'm not getting any reading. I think I will have to get a racepak sensor but don't know if this will hook up to the autometer tach harness. Anyone else ever have this problem?
Liked 345 Times in 149 Posts
Wouldn't it be just easier to get an Autometer slip collar?
Liked 239 Times in 114 Posts
I use a MW collar with my Ultimate II Tach, works great, they are captured and can't come out .
Liked 534 Times in 143 Posts
Liked 520 Times in 132 Posts
X2 that's what I use with my Autometer tach.
Liked 15 Times in 2 Posts
Racepak magnets are SOUTH side out. That is what most hall effect sensors need to trigger. Is the Auto Meter a 2 wire or 3 wire sensor?
I didn't know autometer made a slip collar and other racers told me about the racepak collar so that's what I ordered. It turns out I had a bad sensor, I tried another Autometer sensor and it fixed the problem. Yes the racepak magnets are definitely south side facing out and everything is working fine now. Thanks guys.
Liked 223 Times in 73 Posts
Autometer does make collars they have a universal one that you bore to what ever you need, it is hard to find I dont think it is on the website. Got mine for a 9 inch ford years ago from summit. If this is on your fox body here is what i did on mine. Got some magnets online the little super magnets 1/4 round, drilled my rear end yoke glued in with a 2 part expoxy. Mounted my sensor off a braket one of the holes in front of the rear end. Hope this helps. Here are some autometer collar #
Drive Shaft Collar, 2 Magnet, 1.875" ID Product #: 9378 For use with Ultimate II Playback tachometer driveshaft RPM sensors. Drive Shaft Collar, 2 Magnet, 2.187" ID Product #: 9379 For use with Ultimate II Playback tachometer driveshaft RPM sensors. Drive Shaft Collar, 2 Magnet, Universal Product #: 9380 For use with Ultimate II Playback tachometer driveshaft RPM sensors. Last edited by west coast; 08-07-2012 at 03:36 PM. |
