Old 06-10-2012, 10:12 PM   #21
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default Re: Legal Ford 5.0 head with screw in studs
how do you adjust the stem sweep position with the pedestal setup? It's up a little higher than I want it to be and i can't lower the rocker anymore and pushrod length has nothing to do with it on the pedestal setup. I am using the comp cams 1052 rockers.
'65 Mustang SS/L & L/SA
Old 06-12-2012, 08:54 AM   #22
SSDiv6
This issue has been brought up too many times and it keeps coming back.
Ford is not the only make that has switched to guide plates and studs under the rule changes that have taken place.
The current rules are as follows:
CAMSHAFT/LIFTERS
Pushrod guide plates permitted.
CYLINDER HEADS
The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronze wall valve guides.
ROCKER ARMS
OEM or OEM-type aftermarket rocker arm permitted. Aftermarket rocker arm must be identical to OEM.
In a nutshell, the rule book as printed and as it reads, you are allowed pushrod guide plates and screw-in larger diameter rocker with the OEM style rocker arms.
Ever since this rule was implemented, I have seen many makes of engines, Ford, Oldsmobile and others, go thru teardown with no problems.
I believe the confusion has started with the new rule allowing aftermarket roller rockers which reads they must have the same configuration as OEM.
Old 06-12-2012, 10:50 AM   #23
west coast
Liked 230 Times in 75 Posts
SSDiv6 your last sentance is what I ask Pat about in Phoenix with the new roller rocker rule. He said ask Bruce which I still need to do, but just been to busy.
west coast is offline   Reply With Quote
Old 06-12-2012, 10:13 PM   #24
SSDiv6
Like I said, the rule change allowing guideplates and larger studs was implemented years ago.
http://classracer.com/classforum/showthread.php?t=10993
Old 06-12-2012, 10:33 PM   #25
Earle Holt
Liked 4 Times in 1 Post
Great input! Thanks. Bruce is reviewing this issue as we speak.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 06-12-2012, 10:51 PM   #26
David Lee
Liked 346 Times in 126 Posts
Who is the go to guy for a good set of heads
Old 06-18-2012, 08:37 PM   #27
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Jim Kuntz
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-14-2012, 03:40 PM   #28
7423
Is Bruce still reviewing this for you? Love to know what the ruling will be this time.
7423 is offline   Reply With Quote
