Old 08-17-2012, 11:36 PM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool 327 head gaskets?
Who makes a stamped steel SBC head gasket .038-.040" thick compressed? Got a deck height issue I'm trying to correct. Also, what is the part number? Thanks!!
Old 08-18-2012, 08:11 PM   #2
tj310
Default Re: 327 head gaskets?
Nobody , just run a composite gasket. ---Trevor
Old 08-18-2012, 10:36 PM   #3
Liked 1,892 Times in 423 Posts
There is no single steel or stainless shim gasket I'm aware of.
Cometic has an MLS gasket that will be in that range, you can pick your bore size, and you can use them 3-5 times if you're careful. They pay for themselves that way.
Old 08-19-2012, 07:18 AM   #4
james schaechter
We use cometic head gaskets all the time. They make nice stuff. As Alan said, they can be reused several times. I just tried out their mls header gaskets recently, and they are awesome! Tell them the thickness, bore size and engine.
James Schaechter 3163 STK
