Old 08-26-2012, 12:52 PM   #1
sportsfan
Question weather guages
Can anyone suggest a good set of weather guages? I recently bought an Acu-rite model 00639W.The temperature seems to be incorrect.I also need a dew point reading,but would like to spend under $100.
sportsfan is offline   Reply With Quote
Old 08-26-2012, 02:27 PM   #2
BlueOval Ralph
Banned
Default Re: weather guages
As I remember you can get dew point off the Goverment charts from wet and dry bulb readings.
The Kesteral hand help units are very good the give you everything but they are in the High $ 350 range
Best one is Kesteral 4000
BlueOval Ralph is offline   Reply With Quote
Old 08-26-2012, 03:39 PM   #3
sportsfan
I have printed out a chart that uses temperature and humidity readings to give a dew point,and seems to be accurate. I now need to find a decent set of gauges. Thanks.
Old 08-26-2012, 07:19 PM   #4
Barnstorm
Barnstorm's Avatar
airdensityonline.com/tracks...within 150ft. I can't tune 150ft.
Old 08-26-2012, 11:07 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Try this -
http://airdensityonline.com/tracks/
Looks to be some good info. I started to use the Kestral Motorsports model this year. Took me a while to get used to the calibration, , but once there it worked fine.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 08-28-2012, 08:31 AM   #6
tj310
http://www.dragtimes.com/da-density-...calculator.php - We use inexpensive gauges from W mart. Trevor
Old 08-28-2012, 08:24 PM   #7
vic guilmino
Liked 56 Times in 21 Posts
go to wal-mart and temp. and hum. gague
go to airport and get a used altuder ( spelling wrong) uyou can get on for about $50 dollars
Vic Guilmino 1129 STK
