Old 09-05-2012, 01:55 PM   #1
rx dealer
Liked 53 Times in 13 Posts
Default It's Time to combine the Index
It's time for NHRA to combine the index for Auto and Stick classes in both stock and super stock. I'm running a stick car in super stock and i ran against an auto car in time trials, we both run in GTE. my index is 10.50 and his is 10.65 !! fair? Hell no and i have seen worse!
1. combine both auto and stick index
2. no weight breaks or penalty for auto or stick
3. keep it simple and fair
Thanks...Luke SS 311
rx dealer is offline   Reply With Quote
Old 09-05-2012, 02:51 PM   #2
4406mopar
Liked 120 Times in 53 Posts
Exclamation Re: It's Time to combine
OK , so if they combine and use the quicker of the two indexs, will you be happy? All your Automatic friends won't be. Lets not encourage them to screw it up more than they already have.
Lets fight to get class winners in the eliminator, and get rid of the combo classes.
4406mopar is offline   Reply With Quote
Old 09-05-2012, 03:44 PM   #3
Tony Janes
Default Re: It's Time to combine the Index
It is very fair, that is part of a handicap eliminator.
Tony Janes 7941 STK, SS
Old 09-05-2012, 04:03 PM   #4
rx dealer
4406mopar...it doesn't matter if NHRA goes to slower or faster index...and tell me how is it going to make Auto guys unhappy? Luke SS 311
Old 09-05-2012, 04:12 PM   #5
rx dealer
[QUOTE=Tony Janes;344635]It is very fair, that is part of a handicap eliminator.[/QUOTE
you're right tony. I / we are being handicapped for running a stick...Luke SS 311
Old 09-05-2012, 04:40 PM   #6
Tony Janes
Makes no sense to me, you do not have to run the automatic car heads up.
Old 09-05-2012, 05:30 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
Don't forget some of the stick horsepower ratings are less than the same combo with an auto. Thus the index difference. At least with my combo in SS.
Mike Pearson 2485 SS
Old 09-05-2012, 07:10 PM   #8
Jeff Lee
Jeff Lee's Avatar
The reason some of the HP ratings are less for the stick cars is because less people race stick cars. It's a lot easier to be "king of the Hill" in a Stick class as the classes are so small. You may not be pushed very hard to go any faster.
The reason auto cars have higher HP ratings is because the class is inundated with automatic cars. More hot dogs with ego's equal more nips at the AHFS.
One MAJOR reason guys don't race stick cars is because they loose qualifying positions by racing a stick! Rob Youngblood can tell you how many sales he's lost because of this!
As I said in a recent post, SS/JA vs SS/J; Don Little vs. Rob Youngblood. Both seem to run comparable ET's in qualifying yet Don will qualify in the top 5 while Rob will qualify 10+ positions down the ladder. Same HP rating, same weight (or at least within a few pounds). Is that reasonable?
And some of you think this is nothing more than a bracket race so qualifying means little to you. Well, there are some of us that still adhere to the calling that this is a performance based class and qualifying higher than lower means something!
Now, I have proposed this on this board more than once. Sticks and autos should be combined. I have also proposed that points should be awarded for top 10 & #1 qualifying positions. That would encourage some of you to let loose of the throttle stops every now and again. If that were the rule, that there are points on the line, then why should there be a disparity between indexes on stick vs. auto?
I'll soon be back in D/S. Last issue of Nitro Joes (which every class racer should subscribe too!), Joe lists 8 competitors in D/S. Then look at D/SA. There's 63 in that class! Combine them and now we have 71 cars in a class and one less class. In D/S the two fast guys are Duzac & Byrd @ 10.35 each (wow!) but the two fast guys in D/SA are VanLant & Hill @ 10.51 each.
Apparently there's an advantage to the stick there. But look at C/S vs. C/SA. In C/S the two fast guys are Wenzel & McNeish @ 10.51 each but the two fast guys in C/SA are Dean & Ratcliff both @ 10.37 each. Apparently the auto has an advantage here.
In fact, I just went over all the Stock runs. Of the 25 classes from AA/S through W/S and AA/SA through AA/SA and looking at only the fastest in each class, the autos win 17-8! Stick wins in: B/S, D/S, G/S, O/S, Q/S, T/S & W/S (there are no R/S & U/S racers listed as participants). I didn't count the FWD classes.
So if your crying that the stick has a huge advantage, it just doesn't appear that way.
Combine the classes and I personally could care less how they split the Index. Take the high, take the low or split the difference. One way or the other, NHRA will say the AHFS will take care issues.
NHRA would cut 25 classes and save on trophies. I think this would also eliminate the "Stick / auto combos" which I'm still not sure what I think of that program. But that's for another thread.
More:
Of the 27 classes SHOWN:
7 are the same, stick / auto index
7 are .05 apart
6 are .10 apart
3 are .15 apart
1 IS .20 apart
2 ARE .25 apart
So in Stock at least, there's not the big gap of stick / auto indexes to be concerned about. Unless your one of the (very) few with sticks in the slowest classes.
Here's the index table:
Stock Indexes
Last Update: 9/4/2012
Class 1/4 Mile 1/8 Mile
AA/S 10.00 06.50 - Auto is SAME
A/S 10.95 07.06 - Auto is .05 SLOWER
B/S 11.20 07.21 - Auto is .15 SLOWER
C/S 11.35 07.31 - Auto is .05 SLOWER
D/S 11.50 07.39 - Auto is .05 SLOWER
E/S 11.65 07.47 - Auto is .05 SLOWER
F/S 11.80 07.57 - Auto is .05 SLOWER
G/S 11.90 07.62 - Auto is .10 SLOWER
H/S 12.00 07.68 - Auto is .15 SLOWER
I/S 12.20 07.79 - Auto is .10 SLOWER
J/S 12.35 07.89 - Auto is .10 SLOWER
K/S 12.55 08.00 - Auto is .10 SLOWER
L/S 12.70 08.08 - Auto is SAME
M/S 12.85 08.18 - Auto is SAME
N/S 12.95 08.22 - Auto is .05 SLOWER
O/S 13.10 08.32 - Auto is .05 SLOWER
P/S 13.35 08.46 - Auto is .10 SLOWER
Q/S 13.65 08.62 - Auto is .15 SLOWER
R/S 13.95 08.79 - Auto is .10 SLOWER
T/S 14.40 09.04 - Auto is SAME
U/S 14.65 09.17 - Auto is .20 SLOWER
V/S 15.25 09.51 - Auto is .25 SLOWER
W/S 16.40 10.17 - Auto is .25 SLOWER
FS/S 09.90 06.44 - HUH?
AAA/S 09.70 06.32 - Auto is SAME
BB/S 10.30 06.68 - Auto is SAME
CC/S 10.60 06.86 - Auto is SAME
Jeff Lee 7494 D/S '70 AMX
Old 09-05-2012, 07:44 PM   #9
Jeff Lee
Jeff Lee's Avatar
Here is the Super Stock Indexes:
Super Stock Indexes
SS/AH 09.30 06.08
SS/A 09.65 06.28 - Auto is .25 QUICKER
SS/B 09.90 06.44 - Auto is SAME
SS/C 10.05 06.53 - Auto is SAME
SS/D 10.20 06.62 - Auto is SAME
SS/E 10.25 06.65 - Auto is .10 SLOWER
SS/F 10.35 06.71 - Auto is .10 SLOWER
SS/G 10.45 06.77 - Auto is .10 SLOWER
SS/H 10.50 06.80 - Auto is .10 SLOWER
SS/I 10.50 06.83 - Auto is .20 SLOWER
SS/J 10.80 06.98 - Auto is .20 SLOWER
SS/K 11.00 07.10 - Auto is .25 SLOWER
SS/L 11.25 07.24 - Auto is .20 SLOWER
SS/M 11.60 07.45 - Auto is .25 SLOWER
SS/N 11.95 07.65 - Auto is .20 SLOWER
SS/O 12.20 07.79 - Auto is .10 SLOWER
SS/P 12.50 07.97 - Auto is .15 SLOWER
GT/A 10.00 06.50 - Auto is .10 SLOWER
GT/B 10.10 06.57 - Auto is .15 SLOWER
GT/C 10.20 06.62 - Auto is .20 SLOWER
GT/D 10.35 06.71 - Auto is .15 SLOWER
GT/E 10.50 06.80 - Auto is .15 SLOWER
GT/F 10.60 06.86 - Auto is .20 SLOWER
GT/G 10.75 06.95 - Auto is .15 SLOWER
GT/H 10.85 07.01 - Auto is .20 SLOWER
GT/I 10.95 07.06 - Auto is .25 SLOWER
GT/J 11.05 07.13 - Auto is .25 SLOWER
GT/K 11.10 07.16 - Auto is .35 SLOWER
GT/L 11.30 07.27 - Auto is .25 SLOWER
GT/M 11.50 07.39 - Auto is .25 SLOWER
Of the 30 classes shown:
3 are the same, stick / auto index
6 are .10 apart
5 are .15 apart
7 are .20 apart
7 are .25 apart
1 is .35 apart
SS/AH is one class, stick & auto COMBINED.
Old 09-05-2012, 08:18 PM   #10
rx dealer
Thanks Jeff very informative and proves my point...Luke SS 311
