Old 09-05-2012, 08:12 PM   #1
Jeff Kempton
Jeff Kempton's Avatar
Liked 67 Times in 31 Posts
Default 1987 Mustang 5.0 stocker questions
I've read some of the earlier threads on Mustang 5.0 stockers, and the general consensus seems to be that the earlier carbureted version is the best to build as a Stocker. However, what about a 1987 fuel injected model? A friend is wondering how tough it would be to convert his into a Stocker to run in our local Stock/SS combo series. We run under IHRA rules, so I think that'd put him in G/FIA with an Index of 13.05. Under NHRA rules his class would be M/SA with an Index of 12.85. Good so far?
Racing locally with the Atlantic Canadian Stock SuperStock Association, he wouldn't have to worry about a heads up. My question is; how difficult/expensive would it be to get this combo to run 2 to 4 tenths under the Index, and what areas would you suggest he focus on? He's on a budget and is just looking to come play, not dominate the qualifying sheets!
Can this combo succeed as a "Dime Rocket"? LOL Thanks in advance for any input!
Jeff Kempton is offline   Reply With Quote
Old 09-06-2012, 09:11 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: 1987 Mustang 5.0 stocker questions
ok i'll bite. cam,long tube headers,shocks, drag spring set,gears, set of 30''
radials,c-4 trans,convertor. i'm probably missing some stuff here but it's a start.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 09-06-2012, 10:24 PM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
My 89 GT had a $900.00 short block, $100.00 pistons, stock rods with ARP wave-loc bolts, Lunati stick-shift cam, lifters modified by Cliff Sherman, Jerico trans,514 gears and ALL the stock wiring harness, gas tank , and even power windows, easily ran 50-96 under the index in M/S, N/S, O/S, and G/FI, and H/FI, my 10th run on the car( me being very stocker illiterate) was -.36 under the index, actually at my first race , I ran the index on the third run.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 09-07-2012, 09:35 AM   #4
Chris1529
Liked 70 Times in 29 Posts
You could run it as a pure stock if you are running under IHRA Rules.
It would take a little more work to run as a regular stocker.
Also depends on how much RPM you want to run. I highly suggest at the very least putting an SFI vibration damper on it if you are using the stock bottom end.
I don't think it would be considered a dime rocket given the price for a full race C4 and converter, or a new stick trans with bellhousing, clutch, and shifter.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-07-2012, 10:00 AM   #5
Lee Valentine
Liked 319 Times in 68 Posts
Not too hard, built one a few years ago on the cheap,went a second under H/FIA index for under $ 5000 total. 5.13 gears blueprint cam, valve job cc,ed heads homemade low $ ring package, C-4 and 4500 conv. 24# injectors and used accel gen.-6 efi system,9X30 radials, summit long tube headers ,homemade X pipe, 4 cly springs 12.21-106.06.Lee Valentine.
Lee Valentine 1661 STK
Old 09-08-2012, 08:08 AM   #6
Jeff Kempton
Thanks guys; that's the sort of info I was looking for.
Based on the feedback it sounds like it is do-able on a budget; now the owner just has to decide if he wants to go through with it. Regarding Pure Stock or even a Crate Motor option; I looked at those, but the nearest races besides our own series are all NHRA events, and if he goes through the effort it'd be nice to leave those options open in case "road trip fever" strikes him!
If anyone else has any suggestions I'm all ears.
