Old 09-13-2012, 07:53 PM   #21
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: 305 Stocker Block Question
Where in rule book does it say anything about has to be 2 bolt block?
Mike Taylor 3601
Old 09-13-2012, 08:34 PM   #22
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Originally Posted by nolongerracing View Post
After approving the Dart SHP block for stock and superstock, do you really think that NHRA cares what you do with your $50 305 block? Do you think they are ever going to look at a bottom of an engine again?
I don't use a 305 block. As I stated, I use a 307 or 350 block.
All the things I do to my blocks (block true, lifter true, align hone, etc), need to be done to a new Dart block as well. If you have never used one you should note that they don't come finished.
The fact that Dart is not making a "small bore block" means you will need to install sleeves, just like we do in 307 & 350 blocks. The only difference is that we start with, as you put it, a $50 block instead of a $2000 block. The required prep work is the same.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 09-13-2012, 10:14 PM   #23
nolongerracing
Liked 72 Times in 27 Posts
You are missing my point....NHRA doesn't care if you put 4 bolt caps on a 305. They don't care if you cross bolt a 428 or 390 FE or 440 Chrysler. They don't care. Thats why they approved all the aftermarket blocks.
nolongerracing is offline   Reply With Quote
