Old 09-14-2012, 07:01 AM   #151
Marty Knox
Liked 44 Times in 19 Posts
Default Re: The damage recently done
Originally Posted by Michael Beard View Post
Spy photo of the new Billy Nees Dime Rocket wood-gasifier and propane powered GMC truck. Think it fits V/SA...
Does each of those tubes count as a cylinder? If so, it can't run V/SA - I think there are more than 6!
Marty Knox is offline   Reply With Quote
Old 09-14-2012, 07:26 AM   #152
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
You should see the cost of the approved wood chips you have to burn in the gasifier to pass fuel check...
Old 09-14-2012, 07:43 AM   #153
Billy Nees
Liked 7,892 Times in 1,754 Posts
And it gives new meaning to the old phrase "put it to the wood!".
I like the paint.
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 09-14-2012, 08:11 AM   #154
Todd Hoven
Guest
Posts: n/a
Originally Posted by Jeff Lee View Post
Pontiac started all of that. I'll bet engines ran real good with 320* of duration!
To bad that's the way they came! Pontiac was one of the only manufacturers that put enough cam and valve spring in their performance engines. First computer designed cam to go in a production car, 1968 ram air 2 Firebird. That was the 041T cam used later in the Ram 4 cars.
Old 09-14-2012, 08:16 AM   #155
Todd Hoven
Guest
Posts: n/a
That's a sleeper combo!! 351 V6 ! Solid lifter cam ! Rated at 125 HP! Idles around 400 rpm. With the high flow 350 CFM Stromberg 2 barrel. He is going to build a 6 into 1 header for it! Now if we can get some paperwork for an over the counter 780 Holley , and aluminum intake we would be talking!
Having a picture of Billy without a hat, is like a picture of a Yetti! Very rare.
Old 09-14-2012, 01:09 PM   #156
Ken Haase
Is the hacksaw used to adjust the length of the velocity stack(garbage can)?
Also, prudence demands a second fire extinguisher, possibly a third?!
Ken Haase is offline   Reply With Quote
Old 09-14-2012, 07:59 PM   #157
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
this is funny because we stuck a factory ram air 4 cam in a 74 TA with 8:1 compression and we did get it to idle (it was a mess ) but this thing had a power band like a two stroke dirt bike ,,, and that was the hot ticket back in the day gmonde
Old 09-14-2012, 09:51 PM   #158
Jeff Lee
Jeff Lee's Avatar
Pontiac had advertised durations that far exceeded the actual duration (which was no slouch for the day). And of course it matters where this figure was obtained from (.002, .005. etc)
Pontiac did this for class racing. If a cam had an actual 320* of duration, I'm not sure it would run!
I also had a real deal RAIV / 4-speed / 4.33 rear '69 GTO. Can't imagine what that must be like in a '69 Firebird!
Jeff Lee 7494 D/S '70 AMX
Old 09-14-2012, 10:26 PM   #159
FINESPLINE
FINESPLINE's Avatar
Jeff, Bet you wish you had that Ram Air IV GTO now. Worth a lot of coins. Cars that we had and let go over the years ----Whew !
FINESPLINE is offline   Reply With Quote
Old 09-15-2012, 11:04 AM   #160
Todd Hoven
Guest
Posts: n/a
Jeff, for what it's worth. My Lemans that I raced for almost all my time in class racing started racing life as a bracket car. My first engine was a TRW piston, stock shortblock with d port 4 barrel heads and a Torker intake. The valvetrain consisted of a Crane Blurprint 041t cam and stock rockers.
The duration on that cam at .002 tappet lift was 308 in 320 exh. At .050 231 int 240 exh. 114 LC. That cam idled at 900 rpm with 14 inches of vacuum. I ran 12.18 109 in a 3700 pound car with 4.10 gears and 28 slicks.
That cam was right from Crane. The lobes were in the right place, and it had slow ramps. This is the way those cams were, like it or not.
