Old 09-18-2012, 08:37 AM   #61
Chad Rhodes
Default Re: Fuel Check What's the point???
Originally Posted by Dave Casey View Post
I have raced stock elim every year since 1974, never failed fuel check, I am not the best storer or handler of fuel. I buy fuel at my local vp dealer, the track, a friend who sells it etc.
The only time I remember being close was with some c11 that was 1 1/2 years old
I currently use c12 in both my cars
I really don't think this is as bad a situation as it is being made out to be.
The problems that have happened are rare and correctable, someday it will probably happen to me and I will deal with it. Keep fuel check the way it is That's my preferance
Dave, it does seem to be a bigger problem down here with the high heat and humidity.
Chad Rhodes 2113 I/SA
Old 09-18-2012, 08:38 AM   #62
Dan Fletcher
Sponsor
Dan Fletcher's Avatar
Liked 1,045 Times in 70 Posts
I would vote for random checks during qualifying and only for heads up runs in eliminations, but as someone said earlier, sometimes its not done on a heads up run. EVERY TIME there is a heads up run in eliminations there needs to be scales and fuel check. I remember winning a late round heads up one time in Atlanta years ago, and I had gotten out to actually push the car to the scales, 'cause I knew I'd be dead on and didn't want to burn a drop of gas. When they started motioning me by, I didn't agrue, I just hauled ***, lol.
Dan Fletcher 1781 STK, SS, COMP, SG, SC
DAN FLETCHER TRAILER SALES
Dan Fletcher is offline   Reply With Quote
Old 09-18-2012, 08:42 AM   #63
KRatcliff
Liked 534 Times in 143 Posts
You probably sweated out the difference.
KRatcliff is offline   Reply With Quote
Old 09-18-2012, 08:57 AM   #64
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Originally Posted by Crew Chief View Post
Bingo!!!!! I think you have narrowed the problem down to Sunoco Purple since other fuels seem to be passing. If racers with jugs of older Sunoco Purple can pass and those with new drums of Sunoco Purple do not....the answer looks pretty evident.
Its not really a "BINGO" since we race two cars and use the same fuel.
Fuel check has never been a problem at a Division race,but I have been to a couple of additional National events (Bristol and Brainerd) and ironically,those were the places where the fuel was "borderline".EVERYWHERE else,NO problem...either car. (same fuel)
How can you explain going to a Division race with good fuel,going to a National event with "borderline" fuel,and then to a Division race with good fuel all in a few weeks time?
Would you say "BINGO",this fuel is no good?
Old 09-18-2012, 04:21 PM   #65
Dennis Banach
I have been away from class racing for quite a few years so I`ll start from the beginning of my recent experience ,right before the "Dutch Classic" last year I was given the opportunity to borrow a car for the race,the car had sat under a cover outside for about 1 year it had approx. 1/2 tank of C12 in it.
The car needed some minor work and and we did not have a lot of time to get it ready, Dennis Chapman (The cars Owner) Thought we should drain the fuel and add fresh to be sure it would pass fuel check,to make a long story short I did not drain it but brought some empty jugs along just in case,I also purchased 5 gal.s of fresh C12, Prior to the 1st. Qualifying pass I ran the car over the scales and had the old and new fuel checked,both passed!
One thing that Dennis told me to do was a soon as your done drawing the sample from the car was to cover the container with the palm of your other hand as you walk it over to the table,I have not seen this mentioned and I don`t know if it matters but I have not had a problem with fuel check.(Checked 8 times this year)
Fast forward to last weekend at Englishtown we set the C/FS record, as many of you know when you set the record you are given a tech card with the car weight and fuel test #s and the engine is sealed,then on the back up run the weight and fuel numbers are are recorded again,here`s the thing that struck me funny, the same fuel was in the car, we did not add a drop after the 1 st. run but the fuel check numbers on the card were different ! It passed both times but I wonder why there was a difference a few hours latter? Maybe temperature has something to do with it?
With fuel cost being what it is I do think that if fuel checks lower then it should you should be allowed to run it. Just my opinion!
Dennis Banach is offline   Reply With Quote
Old 09-18-2012, 05:34 PM   #66
Mike Croley
There are a number of chemical additions to race gas that would make it test "lower" than spec but would increase performance. Meaning that a fuel could be off spec because it's old, because it's contaminated, or because it's been doctored.
Renegade Racing Fuels were just added to the accepted fuels lists this season and every grade submitted was very carefully tested by NHRA to be sure the spec sample was representative.
Mike Croley is offline   Reply With Quote
Old 09-18-2012, 08:21 PM   #67
JOE ZOOM
Liked 55 Times in 17 Posts
After reading many of the post on this topic the conclusion is obvious.The gas companys are providing us with fuel that has a shelf life of somewere between a year and a day.Well maybe its my fault i didnt hold my hand over my cup during fuel check.Or worst then that I let the sunlight hit it or I forgot to make the sign of the cross when im fuel the car up,that must be it.We are paying a premium for a product and when that product doesnt do what its suppose to do YOU did something wrong.
Joe Mocci
1424 m/sa
JOE ZOOM is offline   Reply With Quote
Old 09-18-2012, 08:44 PM   #68
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Joe Mocci
1424 m/sa
Fix the test - the fuel check guys do their very best to help us but they do not make the rules if you show up as a DQ on a run - YOU ARE ILLEGAL - whether they say that or not - ask any one in any sport what DQ means
They do not know what they are testing for and the TEST IS FLAWED - it is not the few guys who know what they are doing and occasionaly - seemingly randomly are accused of cheating without using the word - I say throw them out of the race and then more of you guys would get it and tell NHRA to FIX THE TEST - the reason they don't kick you out is they know the TEST IS FLAWED
I suppose if they told you - if you roll up one pant leg above the knee when you walk your fuel over you will pass - 85% you guys would do it and believe it - LMAO
THE TEST IS FLAWED
Ron
BTW - a higher number does not mean more power just like a low number does not mean less power - Geez you guys get a grip - learn what they are testing for specifically and how the test actually works
Old 09-18-2012, 08:58 PM   #69
billy leber
Liked 10 Times in 1 Post
Originally Posted by Toby Lang View Post
I always love it when you have a heads-up race in the later rounds and they have cones up in front of the scales and they wave you by both the scales and fuel check.
It's the most important time to check weight and fuel and they don't do it? Maybe before they close the scales they could call up to the tower and ask if they have any heads-up races this round, but that's probably too much to ask.
Heads up should be weighed and fuel checked every time , other than a heads up I dont care if the guy im racing is 1000 pounds light and runs nitromethane ,actually I would prefer he did both.
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 09-18-2012, 09:22 PM   #70
JOE ZOOM
Originally Posted by billy leber View Post
heads up should be weighed and fuel checked every time , other than a heads up i dont care if the guy im racing is 1000 pounds light and runs nitromethane ,actually i would prefer he did both.
x2
