Liked 33 Times in 15 Posts
Installing CE solid bushings in my 78 Camaro. They say to invert the upper bushing that you replaced and use it as the lower. There is a steel sleeve that prevents the rubber part of the bushing from contacting the frame which prevents the frame from tightning up on the body. Trim the steel sleeve, or use a shorter bolt with a washer and bolt it up solid?
Joe Marcinowski 3377 I/SA
Joe Marcinowski 3377 STK |
Liked 7 Times in 5 Posts
shorter bolts and a nice thick washer works well . Mike
Mike,
Thank you for the response. Later, Joe
