Can someone help me decode this vin # 11427WRNO59444 said it's a 1971 nova ss 350 /270 blue on blue 12 bolt Thanks. John
#2 | |
Liked 68 Times in 41 Posts
this may help http://www.novaresource.org/v71.htm
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
EXAMPLE:
![]() Your Vin doesn't look right and it can only tell you if it was a V8 or L6 car. A 11427 is a V8 2 door sedan. |
Liked 334 Times in 181 Posts
me thinks ya got too mwillow any or the wrong numbers here--- is this the VIN number or the cowl tag???
Anyway 114271W059444 breaks down this way 1---GM Division---- chevrolet 14--Model series----novaV8 27---Body style---2 door sedan 1--- model year ---1971 W---assembly plant----Willow Run 059444---production sequence number do not understand the other letters/numbers you posted but that is what the number should look like |
Thank you for the info, waiting for the cowl tag #s
Hi Jonny, If you're trying to figure out if it's a real SS, I don't think that you can. I think that the best you can do is find enough of the right option #s in the car to assume that it's an SS. Got a build sheet?
In some cases Cowl tags have no bearing on the way the car was originally built---stamped as 4/6 cylinder and built with a V8 or vice versa--it usually is more concerned with trim/color/interior and production plant sequence other pertinant info etc---yes I know it says V8 but is it really a V8---also since 40 years has elapsed many bootleg recreations have appeared---case in point 66-67 Chevelles with 396 engines---there are probably more 396 cars running around now than GMever built---look for thr build sheet as well as warranty books previous owners etc.
Liked 285 Times in 87 Posts
Johnny... If you are trying to figure out if it is a real SS car, go to the rear and see if it has a factory exhaust hanger on the drivers side. All SS cars came with factory dual exhaust and should have factory hangers or mounts spot welded in place. Another factor is any 4 barrel car has 3/8ths fuel line and all SS cars have it. The same follows for Chevelle's and Camaro's.
#9 | |
Hi Maurice, yes it has a 3/8s fuel line and the ex hangers. Has a12 bolt rear to. And yes Billy you are right .
