Liked 4 Times in 1 Post
Has anyone ever had an issue with using a 2 bolt main, small block chevy for stock eliminator? I have built 2 bolts for bracket 350's and never had an issue. Thanks
Chris |
Liked 20 Times in 15 Posts
way back in the old days, there were NO 4 bolt blocks, and not even cap conversions. everyone used two bolt blocks. granted there were no 4" pistons pushing on the mains. but there were more alterdes, gas dragsters and JR. fueleres running with 2 bolts blocks than you could count with a calculator.
in this day of good line hone systems, good main studs, good oil and oil systems and much better bearing tech, there is no reason a 2 bolt block can't live. one thing happens to racers, when someone moves up a step, everyone else thinks they have to, until that step becomes the norm. you can move up until your money runs out. but until you get to top fuel or F-1, there is ALWAYS something better. ego makes things difficult. use a 2 bolt and then lie to your friends. rod in AZ |
I feel the same way. Very nicely put. Thank you.
![]() Chris |
Liked 308 Times in 103 Posts
I like everyone wants to sell a their 350 it's always a 4blt.,or tell you their car has a 350 4blt. like it adds HP.
Another way to look @ it is 4blt has 2 more hole drill in main webbing. Rod's post pretty much covered it Mike Taylor 3601 |
Thanks.
Liked 333 Times in 180 Posts
I think part of the reason 4 bolts were used in some applications was for durability/engine life like in trucks or marine engines. RPM ranges also come into play here too. Stock/Sprint car/endurance racing where you are off and on the throttle constantly tends to want to stretch the cranks. Using a 2 bolt crank in a low RPM NHRA Stock class car equipped with a Small Block Chevy engine where the engines are not running extremely high RPM (like over 9500-10,500 or maybe more) in most cases would probably be sufficient.
Yes for the added insurance that a 4 bolt offers it's probably worth the extra $$$, but to just go out and build a 4 bolt from the get go for a 6800-7000+ RPM short burst engine might not justify the extra cost but you can always convert the block from 2 to 4 (if the rules allow it) if you feel you need a to. my 2 cents worth FED387 |
