Old 10-18-2012, 02:30 PM   #1
Rich196
Default 1998 gmc 3500 dually...
Up for sale is my 1998 GMC 3500 Dually, VORTEC 454, 2WD Truck has ALWAYS been taken care of, I am the second owner (bought it from my brother in law), It does have some minor dents and scratches here and there, and both rear wheel wells have some minor cracked fiberglass, but over all in good shape. In like the year year or so, I replaced the fuel pump, rt front upper A-arm, idler arm, Universals, and 2 new front tires (under 1000 miles on them). This truck has many upgrades, It has installed in the bed a 100 gallon aluim. fuel tank that is plumbed to the regular gas tank, so you can hold roughly 134 gallons at once. (It's GREAT when towing on a long trip,cut's gas stop's in half) , it also has a class 3 towing hitch package with brake box installed, it also has a 5th wheel hook up with trailer plug in the bed., it has a sleeper cap that is rugged inside (the 100 gal. fuel tank sits under the cap), it has Alcoa aluminum wheels all around, The center cap is missing in the pic. they forgot to put it back on when I put new tires on. In the pics. the truck is dirty, I will be getting it detailed in the next couple weeks... The wheels shine up like CHROME. Truck has 135,000 WELL MAINTAINED miles on it...OIL changed every 4-5k miles, you will be able to tell when you see how good the oil pressure is. I am asking in the range of $6500.00, but I WILL TAKE A TRADE.... looking for a compact car that get decent gas mileage, other trades will also be considered. I will have a ton of additional pics after i get it detailed. Like i said, it does have it's bumps and bruises (minor) but this is A SOLID TRUCK, DRIVES STRAIGHT AS A ARROW WITH NO VIBRATIONS. For the last 3 years i only use this truck to go to work daily, 16 miles round trip, and home depot runs. We currently own a motor home and I don't need it anymore for towing. The interior is in GREAT shape, no rips or tears, the seats still as firm as they did when brand new. You can contact me email schrines2000@yahoo.com, or text me at seven three two eight one four eight two five nine. REMEMBER I WILL MAKE A TRADE!!! IF YOU HAVE SOMETHING FOR TRADE, HIT ME UP.
GMC Sierra 3500 Dually Standard Equipment
EXTERIOR
Solid exterior paint
Chrome front bumper
Painted rear step bumper w/step pad
Argent painted grille
Single rectangular halogen headlamps
Daytime running lamps
(5) Roof marker lamps
Cargo area lamp
Tailgate lamps
Dual black foldaway mirrors
Intermittent windshield wiper system
Removable tailgate
Insulation under dash & floor covering
INTERIOR:
Scotchgard Fabric Protector on all cloth & carpet surfaces
Color-keyed molded vinyl floor covering
Simulated leather steering wheel
Passlock theft deterrent security system
Gauges-inc: speedometer, tachometer, odometer, trip odometer, voltmeter, fuel level, engine temperature, oil pressure
Lights-on warning buzzer
Heater/defogger w/side window defoggers
Rear passenger heating ducts
ETR AM/FM stereo-inc: seek-scan, digital clock, 4 speakers
Glove box w/latched door
Passenger side instrument panel storage bin
Dual cupholders on instrument panel
Dual dash mounted power outlets
Cigarette lighter
Molded plastic door trim panels w/dual padded armrests
Color-keyed cloth headliner
Dual color-keyed padded cloth sunshades w/LH storage strap, RH vanity mirror
Passenger assist handle
Lighting-inc: dome, reading, ashtray, glove-box, illuminated entry feature, underhood
Dual coat hooks
MECHANICAL
Full-floating rear axle
Rear wheel drive
100 amp alternator
8-lead trailering wire harness
Double-wall steel construction 8' pickup box w/extensive corrosion protection
10,000# GVWR (3600 front/7500 rear), springs (3600 front/7500 rear), axles (3800 front/7500 rear)
Independent front suspension w/coil springs
Leaf spring rear suspension
1.25" Front stabilizer bar
Dual rear wheels
(7) LT225/75R16D all-season SBR BSW tires
16" silver painted steel wheels w/black center cap-inc: spare wheel
Winch-type spare tire carrier (under rear frame)
Speed-sensitive pwr steering
Pwr front disc/rear drum brakes
Four-wheel anti-lock brake system
34 gallon fuel tank
Aluminized stainless steel exhaust system
Mechanical jack & wheel wrench
Single, two-sided key
SAFETY
Manual lap/shoulder safety belts, front/rear outboard seat positions
Front outboard shoulder belt height adjusters
Manual lap safety belts, center seat positions
Energy-absorbing steering column/instrument panel
Head restraints, front seat
Side door guard beams
Single note horn
Rich196 is offline   Reply With Quote
Search this Thread:
Advanced Search
