I am wondering if Hydraulic clutch set ups are any good at the track? What are all the new Camaro's, Challanger's, Mustangs etc using ie: stock, Super Stock and braket cars. Someone is trying to tell me there is no place in drag racing for hydraulic clutch set ups. Chris
72GS stage2 455 street/strip best et 9.93 1970 Stage1 iron heads,stock rods. 1.37 60' 10.17@129.8 70 GSX clone, 9.3:1 455 stage2 best et 11.00 |
My opinion is they have no place with a TRUE race clutch setup; i.e., adjustable sindered-iron clutch disk. These are designed to have a controlled amount of slippage on launch with an immediate release of the throwout bearing from the levers by way of mechanical linkage.
A Hydraulic system MAY be good for something like a diaphragm clutch assembly which engages more like an "on/off" switch on engagement. But I haven't put a lot of thought into that... The question should be why do you think you need a hydraulic system in a race car? Have you put your foot on a race unit that is properly designed? I think your average Civic has more resistance.
Jeff Lee 7494 D/S '70 AMX |
#3 | |
Liked 71 Times in 38 Posts
X2, I don't think a hydraulic clutch linkage even belongs in a street car.They have a strange feel to them and do not respond quickly.Hydraulic systems belong in a bull dozer or garbage truck.A cable set up isn't much better.A well designed mechanical linkage is really the only answer. As Jeff said newer clutches have a very light pedal feel.Before I removed the over center spring on my car,it would hold the pedal to the floor. |
Liked 70 Times in 22 Posts
I had an 8.80 Tbird with a lenco and put a McLeod hyd unit in it. Had a single disk McLeod iron unit. Had a delay box and had to run around 1.1 in the box just like with mechanical linkage so I didn't see the hyd setup as not being able to respond quickly. Also don't see the problem with a cable. I am thinking about one in the SSGT I'm building. As long as it is kept lubricated and not tied in a knot I think it will work. I would guess the Fox body Mustangs that came with cable still run them in Stock. And the cars with hyd still run it. My car will be a SS car so it is only used on launch. In an A-body Mopar the drivers side is pretty busy with header, starter and t-bar all fighting for room. Keep the linkage out of there and free up a little space.
I have heard the in S and SS you cant run Hyd or cable but I can't find it in the rulebook. Maybe one of those things, if it doesn't say you can, you can't
Stewart Way 2424 SS |
I am looking at the Ram stuff, check out the valve at the bottom of the page. Chris
72GS stage2 455 street/strip best et 9.93 1970 Stage1 iron heads,stock rods. 1.37 60' 10.17@129.8 70 GSX clone, 9.3:1 455 stage2 best et 11.00 Last edited by Buicksstage1; 11-03-2012 at 11:14 AM. Reason: sp |
Liked 8 Times in 7 Posts
weeellllll, i was told (by NHRA) that i COULD NOT convert to a hydraulic setup on my AMC, so, using that logic, i don't see how you can convert a hydraulic system to linkage (legally)..
without losers,winning means nothing. |
We run a hydraulic setup with a true race clutch , we have made hundreds of passes over the last 6 years with this setup. We had a few issues with leaks and interference initially but it is fine now. The car is an 84 Trans Am we run in stock or s/s
- http://www.howeracing.com/c-534-throw-out-bearings.aspx ---Trevor |
Liked 319 Times in 108 Posts
I'd rather have mechanical linkage,only way it does'nt work is if it falls off,which is easy to figure out and fix.
Mike Taylor 3601 |
Liked 36 Times in 26 Posts
I met a older guy this year that had a NHRA Mustang stocker, and he was the first stocker to run in the eights. He had a hydraulic activated clutch in his car. It depends on you transmission and how much of a challenge you are willing to go though to run a hydraulic unit. If the mechanical linkage in not workable, sometimes a hydraulic unit can make things easier. My street Cobalt has a hydraulic activated clutch, and I believe the Corvette has a hydraulic clutch. I have one in my Super Gas car, which has a Lenco and it works just fine. I have had a couple of knee surgeries and the mechanical linkage with the bell housing, I had at the time, was not the best. So I went with a McLeod throw out bearing assembly. I have had some issues with what I was trying to do at the time, but at the present I am very content. A lot of it depends on whether you have to use the clutch to shift or not. You need to talk to people who run them and find out the good points, and the not so good points. I like mine, and that is the bottom line. I love the sound of a stick car going through the gears.
Steve Williams Super Gas 351N. |
Liked 373 Times in 131 Posts
Alot of the guys in the NMRA Factory Stock class run the cable setup and seem to do o.k.
I've never heard of a big problem from the Mustang group about a cable setup.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
