Old 07-17-2007, 07:25 PM   #1
Ben Kallies
Question Rearend Fluid - Synthetic or not?
I have been given conflicting advice on what type of diff fluid to use. I have a Moser 12 bolt with high-impact race gears and spool in a '71 Corvette Stocker with stick. The gentleman that I spoke with at Moser said that it doesn't matter as long as it's 80w90 weight. An independent differential shop advised me not to use synthetic because it doesn't protect as well with regards to the intitial hit on launch. Still others have told me that is a bunch of bologna and synthetic is the way to go. Anyone willing to share their experience? Thank you in advance for your time. Ben Kallies 3869
Ben Kallies is offline   Reply With Quote
Old 07-17-2007, 07:35 PM   #2
Arnold Greene
Liked 3 Times in 2 Posts
Default Re: Rearend Fluid - Synthetic or not?
For the best life in a stick shift 12 bolt, run 2 quarts of 80w-140 synthetic with approximately 2 ounces of moly mixed in. You will be surprised how well this works and it will not slow the car down.
Arnold Greene
IHRA/NHRA 2420 A/S, B/S
Arnold Greene is offline   Reply With Quote
Old 07-17-2007, 08:51 PM   #3
Woodro Josey
Liked 3 Times in 1 Post
I'd have to go on Arnolds reccomendation,as he has had a lot of dogs in this hunt!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-17-2007, 09:22 PM   #4
Oldtimer
Hay Ben, Sounds like you got your done ! Go with what Arnold said, he and Woodro have been around as long as I have, I dont know if thats good or not. Send me some pix. Regards, bob pagano L88BOB@aol.com
Bob Pagano L88BOB@aol.com
www.dyainc.org
4033 AA/SA
Oldtimer is offline   Reply With Quote
Old 07-18-2007, 07:34 AM   #5
Ben Kallies
Thank you guys. Arnold, is there any particular brand of fluid that you recommend?
Old 07-18-2007, 08:17 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I have had great results with valvoline full synthetic. Its cheap and available at most parts stores. I have a dana in my super stock H/A camaro and usually get about 8 - 10 seasons on a gear set. The gears last alot longer with the synthetic lube.
Mike
Mike Pearson 2485 SS
Old 07-18-2007, 10:03 AM   #7
Arnold Greene
Ben, I've used Mobil 1, Red Line, Royal Purple, Castrol Syntec, and Valvoline. I use whatever is available. Right now, I am using RP, but the weight is more important than the brand, IMHO. Don't forget the moly and make sure the rear is warm to keep it in suspension, before you make a hit. Good luck.
Arnold Greene
Old 07-18-2007, 10:20 AM   #8
John Kelley
Where do you get the "moly"and does it have a brand name ?
John Kelley is offline   Reply With Quote
Old 07-18-2007, 11:05 AM   #9
Ben Kallies
Can I assume that it is OK to break it in with the synthetic as well? Thanks for the help. - Ben Kallies 3869
Old 07-18-2007, 11:19 AM   #10
Arnold Greene
Yes, it is fine for break in. The last moly that I bought was under the name, Mr. Moly. Most parts stores carry it, but it only comes in quarts, that I have found. I think I paid $28 for the last quart I bought. Also helps in the Jerico.
You will most likely have to reset your backlash after your first race. The Pro gears have a tendency to bend the teeth on the ring gear, and then stabilize.
Arnold Greene
