Old 10-30-2012, 12:46 PM   #31
billy leber
Liked 10 Times in 1 Post
Default Re: E85
Originally Posted by Carl Juliano View Post
If the fuel tests in the 70s, which most off season spring and winter blends do, is it still able to be used in 15-16.1 engines?
I would say no . I am assuming the gasoline they mix with Ethanol is low quality so 30% will probably not be welcome .
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 10-30-2012, 01:44 PM   #32
Mike Croley
Default Re: E85
Both VP and Sunoco offer E85 race fuels.
Check with Jeff Stricker at Roadrunner Race Fuels.
He's located right near Maple Grove.
So does Renegade.They offer two.
The Renegade dist. in Florida carries E-85 all the time.
Mike Croley is offline   Reply With Quote
Old 10-30-2012, 08:37 PM   #33
billy leber
Default Re: E85
It's also $10 -$12 per gallon , no thanks.
Old 10-31-2012, 09:58 AM   #34
Mike Croley
Default Re: E85
The Renegade E-85 is around $4 per gallon.
Old 10-31-2012, 01:36 PM   #35
billy leber
Default Re: E85
Thanks , Ill check that out for sure. Do you have a contact number or recommendation on where to buy it.
Old 10-31-2012, 10:18 PM   #36
voltdr
Liked 100 Times in 51 Posts
Default Re: E85
Can you still use an electric fuel pump? Even with jets sizes in the 160s? Or do you have to run a mechanical pump?
voltdr is offline   Reply With Quote
Old 10-31-2012, 10:33 PM   #37
jmarkaudio
Default Re: E85
A belt drive is always nice, but I have run the 1250 with .172 jets using a Magnafuel Prostar 500 and a Magnafuel large 2 port regulator.
jmarkaudio is offline   Reply With Quote
Old 11-01-2012, 09:26 AM   #38
Mike Croley
Default Re: E85
www.renegadepro1.com
Where are you located?
Old 11-02-2012, 12:20 AM   #39
billy leber
Default Re: E85
Buffalo , N.Y.
Old 11-05-2012, 11:21 AM   #40
Mike Croley
Default Re: E85
Buffalo , N.Y.
Call Vince Musolino 315-254-8408
or
The Dyno Shop 203-619-4732
