Old 11-09-2012, 11:30 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default GM steel dually wheels---center bore question
AFTER I bought these sight unseen on ebay---ok I know---16" gm oem steel wheels----I bought a pair of these.........the bolt pattern is the same, the width is correct, the diameter is correct BUT the center bore on one wheel is slightly larger than the stock wheel......does that really matter in any way as long as the bolt pattern is correct ??? After some research I found out the center bore got larger after 2001, obviously I have two wheels each from a different era. Does the center bore carry any load ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 11-09-2012, 11:43 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: GM steel dually wheels---center bore question
Unless your truck is unusual, the wheels are lug-centric not hub-centric so the center hole only needs to be large enough to clear the hub. Make sure the coined lug holes match in size and depth, and the offsets are the same compared to your original wheels. Of course, wheel widths and diameters must match too.
