Old 11-08-2012, 11:46 PM   #1
KURT GROSS
Default 1970 Nova rear differential and brake choices
Building a 1970 Nova for use in Pro Bracket but we are aiming towards stock in the near future. Will be using Calvert bars with split mono leaf springs. I need to purchase a 12 bolt and am considering the Moser housing and axle package as a starting point. Looking for opinions or experience with this option. Seems like you are lucky to find an original 12 bolt close to this price anymore, plus the housing will be about all you actually use if you do find one let alone the work needed to use it.
Second issue is which rear disc brake kit to purchase. Many options, but again looking for opinions.
Thanks in advance for your help!
Kurt
KURT GROSS is offline   Reply With Quote
Old 11-09-2012, 06:26 AM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Re: 1970 Nova rear differential and brake choices
Been using a Moser housing for quite a few years, it's an excellent piece and a great value as compared to finding an original 12 bolt. The housing from Moser will come already prepared for c-clip eliminator bearing set-up.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 11-09-2012, 09:10 AM   #3
Billy Nees
Originally Posted by KURT GROSS View Post
Seems like you are lucky to find an original 12 bolt Kurt
Leave the original 12bolts to the collectors. It just doesn't make sense to pay too much for one and cut it up. Not to mention that you will eventually bend or tear the stock, thin tubes and have to replace them anyway.
Billy Nees 1188 STK, SS
Old 11-09-2012, 09:18 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I would use biggest wheel bearing and housing end,will work better than c-clip eliminator setup.
Mike Taylor 3601
Old 11-09-2012, 10:26 AM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
If you go with moser you can get a end that takes the small gm brake setup but uses a big ford bearing.
Old 11-09-2012, 11:08 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Always the best choice.
Old 11-09-2012, 01:44 PM   #7
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Kurt, I just completed a 68 Camaro that was done with an eye towards stock elim. I went with a Strange 12- bolt with their S-series disc brakes. The best deal I found, by far, was thru Alex at Moneymaker Racing. Very happy with the set-up, and all the tech help from both Alex and Tony at Moneymaker and Strange Eng. I have also run Moser stuff in my 69, and was happy with it,also.
Dana Fitzpatrick is offline   Reply With Quote
Old 11-09-2012, 04:15 PM   #8
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 1970 Nova rear differential and brake choices
Do they both (Moser and Strange) pay contingency money?,,, something to think about too.
Danny Durham
Old 11-11-2012, 08:03 PM   #9
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Danny Durham
In addition to paying product contingency for the finalists don't forget about the Perfectly Strange award for winning a round with a dead on run.
Thanks for the props Dana.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 11-12-2012, 08:47 AM   #10
tj310
They also use 1/2 bolts instead of 7/16 on the caps. ---Trevor
