Old 07-19-2007, 04:16 PM   #11
Dick Butler
Liked 32 Times in 19 Posts
Thumbs up Re: 62 Chevrolet, STILL No Traction
On a good track by someone elses performance changing tire pressure UP 3 or 4 lbs stabilizes tire wall. This fights distortion or wrapping up the surface of the slick. With no one to observe for you the 60 ft time change if present can give hints about whether you are TOO high on instant center or ..... Sounds too High off hand for me. I think it would like more like 6 or 8 inchs. Get an observer to watch or film the rear tire on dropping clutch. My money is on TOO much attempted % rise. Dick
Old 07-19-2007, 04:52 PM   #12
Oldtimer
Default Re: 62 Chevrolet, STILL No Traction
http://aolsearch.aol.com/aol/search?...lover&ie=UTF-8
Here is a link that will give you a page of choices on Instant Center for free.
Bob Pagano L88BOB@aol.com
www.dyainc.org
4033 AA/SA
Oldtimer is offline   Reply With Quote
Old 07-19-2007, 06:26 PM   #13
Leif Andersson
Liked 5 Times in 1 Post
Maybe you find something usefull here.
http://home.earthlink.net/~whshope/
Leffe
Leif Andersson is offline   Reply With Quote
Old 07-19-2007, 08:49 PM   #14
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Originally Posted by NHRAstocker409 View Post
DAMN !
What I failed to mention, is that I am releasing the clutch at about 5000 ( 7000 RPM engine ).
I don't know what you mean by 5000 (7000 RPM engine)??
Do you use a 2 step to set your leave RPM??
Do use a very light weight flywheel to cut down on inertia??
Maybe at a 7000 RPM leave you have all of your centrifugal assist in??
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-19-2007, 09:54 PM   #15
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Oldtimer, that DID go to a list of links. None of them seem to address the what is desireable as a drag racing application.
Not bad there, Leif... but again, no practical diagrams indicating the desired geometry.
As mentioned earlier, Bob... aluminum flywheel ( 11 pound ), aluminum McLeod 10.5" "hat"
What do I mean ?
exactly THAT !
It's a 7000 RPM engine, that makes NO power below 3000, with horsepower peak at around 6700-6800.
With this 7000 RPM engine, I can release the clutch as low as 3500, and still blow the tires right off.
Two step ?
that's a dance, isn't it ? !
Need my "shoes" on the ground before I'll bother to try dancing !
oh... the centrifugal weight that I added.... 8 grams, on each of the 3 release fingers.
Here's a link to a VERY rough sketch that I did up, after I took a whole series of very acturate dimensions:
http://www.bruneauperformance.ca/62b...eometry900.jpg
Bottom picture is exactly as the car is right now.
Upper picture is after my proposed lowering the rear 1 1/2 inches.
The 63" dimension, is a result of lowering the front loer control arm mount at the frame ( not permitted ).
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 07-19-2007, 11:15 PM   #16
Bruce Fulper
Liked 54 Times in 33 Posts
If you got no help use a tripod for the camera. Must be able to see what's going on.
Bruce Fulper is offline   Reply With Quote
Old 07-20-2007, 01:07 AM   #17
Jeff Lee
Jeff Lee's Avatar
"A person can feel the slippage on engagement... the "torue converter" philosophy "
What do you mean " a person can feel the slippage on engagement" ?
Jeff Lee 7494 D/S '70 AMX
Old 07-20-2007, 03:29 AM   #18
Aubrey N Bruneau
Here's that clutch slipping, Jeff:
http://www.bruneauperformance.ca/wat...tstock409.html
can't explain the tires though ? ? ?
and p l e a s e... no more about the "track is God's ground"... time and TIME again, it aint.
but seriously...
Low RPM, high RPM... ?
If this thing planted the tires AT ALL, it would shut the engine off if I tried to dump it at 3000.
Like I mentioned earlier, there is absolutely NO slippage in high gear.
Yes, I do use the clutch to shift ( doesn't the rule book say you have to ! )
The video above, is an old one, with the old tires ( they were relatively new at the time ).
Isn't quite THAT bad anymore. Like I mentioned, rather than bouncing off the rev limiter, and having to "back pedal"... at least now, the limited traction I have, keeps the engine from flaring up like the car's on ice.
You're right, I doubt the lower 1st gear is the miracle cure ( like... not )...
I just wish somebody could tell me where this rear control arm geometry should fall ?
Old 07-20-2007, 10:39 AM   #19
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Make sure the lower link connecting the rear end to the frame is running down in the front at least 2 degrees. Park the car on a level surface and step back and look at it visually first. the bottom bar must run at a down angle ( lower in the front ) in relationship to the rocker panel. If it is running up it will not hook up even on the best track with new tires. You may need to adjust the ride height to correct this problem if it exists. Had the same problem with my super stocker.
Mike
Mike Pearson 2485 SS
Old 07-20-2007, 11:59 AM   #20
Aubrey N Bruneau
Make sure the lower link connecting the rear end to the frame is running down in the front at least 2 degrees.the bottom bar must run at a down angle ( lower in the front ) in relationship to the rocker panel. If it is running up it will not hook up even on the best track with new tires. You may need to adjust the ride height to correct this problem if it exists.
Mike
that bears repeating
all said
THAT is exactly what I am experiencing... no traction, no matter WHERE the tire pressure is !
Mike, it would be basically impossible to make the lower control arm rake "down", while even remotely staying within the rules.
By lowering the car though, I can get a lot closer... and the upper arms will provide that snap down ( up on the body ) on the axle housing when it tries to rotate back under engagement.
Thank YOU, Mike !
