Old 11-12-2012, 02:26 PM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
Default Re: Cooling system pressure
I use Evans NPG coolant with a zero pressure cap.
my spare engine is an old Comp engine that has some heads that leak a little, not unlike some SS heads.
This stuff works great and is race legal as it is not an ethelyne glycole base and cleans righ up.
It boils at 360 deg F at no pressure and has a very low expansion rate.
not cheap, but it works great and can be reused for several racing seasons.
http://www.evanscooling.com/products/coolants/npg-2/
Old 11-12-2012, 03:00 PM   #12
Rob Petrie E395
Liked 216 Times in 77 Posts
What is the advantage to running with no pressure?
On the Evans coolant do you have to run thier pump with it? At one time I thought you did.
Old 11-12-2012, 06:01 PM   #13
Tom Goldman
the big advantage of no ,or low pressure ,is no pressure to force coolant into ports ot combustion chambers.
I run the Evans with a Mezire pump with no problems.
Evans has several coolants and they also offer thermostats ,pressure caps and hi flow water pumps,but I dont recall a specific requirement for using their pump.
