#11 |
Larry, "Cheater Cam" was probably a poor choice of words. I like "enhanced cam specs" better. I think the 427 guys need to get the pencil and paper out and go after that extra 2 thou. That would certainly level the playing field with the Drag Packs, Copos and new CJs.
Rusty |
#12 |
Liked 2 Times in 2 Posts
Rusty,
Crower already has the honda rod in motion for the FE's. They've submitted the paper work to NHRA for approval and its supposed to be accepted next year. I've already got my name on the waiting list with Crower. They are going to call it the "Larry Hill" rod ![]() ![]()
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#13 | |
NHRA tech knows that the intent of that language you quote on the undersizes was put there to keep SPACER BEARINGS out of Stockers............so a guy with a 440 Chrysler like yourself couldn't put a Honda bearing in a spacer, in a Stocker. The FE is not the only engine that has a rod approved with other than a stock journal......it just happens to be the engine that runs your class. If, for whatever reason, a connecting rod showed up on the list for a 440 with even a 2" crankpin, I'd wager that not one Ford racer would belly ache and whine about it. I guess no one runs a 400 block in a 440 combo in Stock either, right? No journal issue there is there Larry? The newer cars have such an advantage over the old ones that it is really a non-issue. Those rods were approved at a time when availability of parts (cranks and rods) was not what it is today. Removing approved parts from any combo of any make will only reduce car count and make it a show for the brand new cars, in the end. For class racing to survive, there has to be some admendments here and there. The vast majority of Stockers are still OLD CARS. There are going to be changes that affect all combos either positively or negatively, from time to time. The changes, while upsetting to the purist, must come here and there to keep class racing alive. The challenge for NHRA is to try to make rule amendments, like the crankshafts this time, that help the racers keep racing. If some Hudson Hornet gets a part that it did not have, or a spec it did not have, the Factoring System will fix it way before it fixes the factors on the newer combos. Any part that helps any combo in terms of reliability and or availability should not be a sore spot at this point, for anyone who realizes that most of us are working with 30-40, even 50 year old stuff, and alot of it is not made anymore. The only answer is for NHRA to try to make changes that are rational and reasonable. I think that is harder to do than it looks. BTW, Ohio crank doesn't MAKE a $500 FE crank. Cheap cranks are imported from China. I would not put a cheap Chinese iron crankshaft in my wheelchair. I would rather buy a good American set of Crower rods, and use a Ford crank, so NHRA won't have to pick up a bunch of Chinese iron off the racetrack when it flies apart and kills a block that is not made anymore. Most who take advantage of the new crank rule will not be buying junk..........that is the whole point of the amendment.........so racers don't have to use junk that they can't find anyway. |
#14 |
Lots of bad info on 440s in that post, WOW!
Please tell us who is using a 400 block and claiming it as a 440 in STOCK....
2009 V/SA Record Holder |
#15 | |
Liked 4 Times in 4 Posts
OK, you are obviously total ignorant about Mopar big blocks. First, the 400 and 440 are completely different physical sizes easily seen by just looking at them; second, there's a big raised pad on the front of a 440 that says: 440, the 400 has a machined pad on the left side of the block that says: 400, both have the block size cast on the side of the block. Different blocks, different sizes and clearly identified. Who would want to give up 40 inches? JimR
Jim Rountree |
#16 | |
Blair Patrick Last edited by CaptCobrajet; 11-18-2012 at 06:40 PM. |
#17 |
Liked 10,781 Times in 2,241 Posts
#18 |
Ahmmm....For whatever it's worth the 413 & 426 wedge also shares the 440 block structure.
Jeff Lee 7494 D/S '70 AMX |
#19 |
Liked 62 Times in 17 Posts
#20 |
Liked 327 Times in 121 Posts
Yes but the Maxi mani doesn't fit a low block (400) without obvious mods but the Edelbrock 383 6 Pak mani fits a 400 block just fine and it's been done. The 400 block is stronger and 25 lbs or so lighter plus the advantage of the lighter piston and rod.
