Old 11-26-2012, 01:02 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default 4GC Air Cleaner base
Where can I get a 4GC air cleaner base like this? Thanks
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 11-26-2012, 09:20 AM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: 4GC Air Cleaner base
If that one is off of normans car it was fab up by patterson. If you look it is two pieces put together. If I remember right if you get a quadrajet from a pontiac then adapt it to the 4gc opening. Tom
Tom Meyer 5240 SS Stock ???
Old 11-26-2012, 02:24 PM   #3
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Ed... That is the standard base from an OEM open element HP air filter assembly. It came on Quadrajet and Holley performance applications 1966-69. Someone has done a clean job of making it work with the 4GC, adapter ring and fuel inlet tube. You most likely will have to make your own from the picture. If you need a base, try Corvette Central or Classic Industries. I hope this helps.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 11-26-2012, 03:35 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
http://www.parts123.com/parts123/yb....~Z5Z5Z50000050
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 11-26-2012, 04:49 PM   #5
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
All I know is that if it not a factory air cleaner base,it can not be higher than the choke horn (meaning if you put a strait edge cross it,the choke horn has to hit it.) had to take it off in the 4th round after they saw it when I was getting fuel checked, another UN-written rule,that was in stock
for super stock
AIR CLEANERS
Optional. If used, air cleaner must be OEM automotive or retain
OEM configuration. Air-cleaner base may be cut or trimmed, but
welding, bolting, riveting, epoxying, or any other form of fabrication
prohibited. Ram tubes, velocity stacks, or other than stock-type
base plates or ducting prohibited. Cooling holes prohibited in
radiator side panels, etc. Factory air cleaners and/or scoops that fit
through hood must be affixed to carburetor as per OEM only.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 11-26-2012, 07:32 PM   #6
magnumv8
EBAY....item # 230835819406
It is a modified one of these......
D L Rambo......Stk 1300
magnumv8 is offline   Reply With Quote
Old 11-27-2012, 12:37 AM   #7
Ed Carpenter
Thanks I appreciate it.
Ed Carpenter
Old 12-19-2012, 01:21 AM   #8
f.i.57chevynut
Try this one : ebay # 130821984840
f.i.57chevynut is offline   Reply With Quote
Old 12-19-2012, 05:39 PM   #9
Ed Sroka
What is particularly appealing about this base?
Ed
Ed Sroka is offline   Reply With Quote
Old 12-19-2012, 05:45 PM   #10
Ed Wright
Ed Wright's Avatar
Ed
Was worth a couple hundredths on my old 250 HP 327" '65 Chevelle convert.
Ed Wright 4156 SS/JA
