Old 07-23-2007, 01:06 PM   #1
3969 Nova
3969 Nova's Avatar
Default cast iron cylinder head repair help
hello everyone,new guy needs some help finding a good cast iron cyl. head repair shop in ny or nj area. have some damage in the chamber due to a dropped intake valve .have a cracked guide and damage to the seat.is this a common repair ?is it worth fixing or should i start over? any help would i would be grateful. thanks again
3969 Nova is offline   Reply With Quote
Old 07-23-2007, 02:13 PM   #2
G Schenck
Liked 81 Times in 35 Posts
Default Re: cast iron cylinder head repair help
Ship it off to INDY CLY HEADS, they can fix it.
Greg
G Schenck is offline   Reply With Quote
Old 07-23-2007, 07:10 PM   #3
Woodro Josey
Liked 3 Times in 1 Post
You have your answer, if you have a lot invested in the head, such as a legal class engine or exotic Bracket head,,,,,Indy Cyl Heads is the place and they do some very nice work! Cast Iron or Aluminum, doesn't matter!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 07-23-2007, 08:20 PM   #4
3969 Nova
3969 Nova's Avatar
thanks for the info guys, do you know a pallpark estimate of how much such work would cost?the heads are just run of the mill merlin heads with no exotic work done at all.
Old 07-24-2007, 11:01 AM   #5
Dave Goob Cook
Dave Goob Cook's Avatar
From the ICH web catalog
http://www.indyheads.com/
All Aluminum And Cast Iron Heads Can Be Welded & Repaired 200.00 Minimum .
If you can find any welding shops local that "oven weld" cast iron, you can save some bucks......
The welder need not be knowledgeable about cylinder heads, if you can mark and prep the wounded areas, they can be fixed.
Dave Goob Cook is offline   Reply With Quote
Old 07-27-2007, 10:06 AM   #6
Joey
Smile Re: cast iron cylinder head repair help
You might want to give Garv's Auto Head Repair a call, they are located in Indianapolis, we sent a pretty well damaged 440 head there and the work was very good and reasonable, the phone number is 1-317-784-8458
Joey is offline   Reply With Quote
Old 07-27-2007, 10:30 AM   #7
Dave Goob Cook
If Garv's is still around, they moved.......
Old 07-28-2007, 11:08 PM   #8
76 RACER
Hey Dave,did Tim have victims at the starting line tonite....lol
76 RACER is offline   Reply With Quote
Old 07-29-2007, 01:45 PM   #9
Dave Goob Cook
Only two confirmed kills for the night!
Did have a happy gentleman with a shiny new Wally tell me that in 34 years of drag racing he'd never been on any track that was better.
First time at tha 'Hill, but not the last.
