Old 12-17-2012, 10:25 AM   #11
tj310
Default Re: 12 bolt R.E. housing question--
Use head studs in place of bolts. Drill through housing and tube put a couple of bolts in to pin them together. ---Trevor
Old 12-17-2012, 11:17 AM   #12
bigsixman
Liked 2 Times in 2 Posts
I was running a 12 bolt with good parts behind a 69 camaro with a 540" bbc and a Jerico. I launched at 5500 rpm and stretched the 7/16 MW cap screw main cap bolts and tore all the teeth off the ring gear. I then upgraded to a Tom's Differentials 1/2" main cap bolts and his cap. I also used a Tom's heat treated ring and pinion and I had no further issues with it until I sold it to a friend and I upgraded to a Strange 9".
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
