Old 12-19-2012, 10:17 PM   #11
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: 4GC Air Cleaner base
Was worth a couple hundredths on my old 250 HP 327" '65 Chevelle convert.
Thats it. Although I need a tenth! LOL
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 12-20-2012, 12:11 AM   #12
Ed Sroka
If we designed a CFD base specifically for the 4GC, would you be able to use it?
Ed Sroka is offline   Reply With Quote
Old 12-20-2012, 12:16 AM   #13
Ty Kwaiser
Ty Kwaiser's Avatar
Liked 33 Times in 11 Posts
2013 rule book, section 11A, page 2
Air-cleaner base may be cut or trimmed, but welding, bolting, riveting, epoxying, or any other form of fabrication prohibited.
Ty Kwaiser is offline   Reply With Quote
Old 12-20-2012, 12:26 AM   #14
Ed Carpenter
If that's the case then alot of air cleaners I've seen need to go in the trash.
Ed Carpenter
Old 12-20-2012, 11:03 AM   #15
Ed Sroka
If it can be used, I'll utilize the CFD programs and design a 4GC base prototype that can be dyno/track tested next week.
Old 12-20-2012, 11:51 AM   #16
Darrin Christen
Darrin Christen's Avatar
My guess would be that if it did not come on that particular combo or carb than your not suppose to use it.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 01-23-2013, 12:16 PM   #17
FED 387
Liked 333 Times in 180 Posts
I have several NEW bases and adaptors to make this type of set up almost the exact thing in the picture---$40 shipped UPS to your door-- let me know by PM please if anyone has interest in them--- you will have to fabricate the attaching rods to hold the base in place but that should'nt be a problem---we made one up in less than an hour
Old 01-23-2013, 12:51 PM   #18
Run to Rund
Liked 54 Times in 27 Posts
The written rule does not specifically exclude an adapter that is simply sandwiched between the air horn and the air cleaner base. For example, Caddy Sevilles, etc. used a riser type adapter, although it did not change the mounting diameter. Now you just need to get NHRA to follow your logic. . .
Old 02-05-2013, 04:56 PM   #19
philbilly
philbilly's Avatar
anyone have one of these for a rochester?? I would like to have one.
philbilly is offline   Reply With Quote
Old 02-05-2013, 05:28 PM   #20
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Late 70's/early 80's small block Chevy pick-ups used an adapter/spacer ring right below the air cleaner base. It was about 3 inches high with a tube for a crankcase vent hose. That would lift things up, but then hood clearance might be an issue.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
