Old 12-20-2012, 04:30 PM   #11
Duster 318
Default Re: what class can i run
i would do a 340 but i already have a good 318 with lots of extra parts
Duster 318 is offline   Reply With Quote
Old 12-21-2012, 01:51 AM   #12
Phillip marvetz
Phillip marvetz's Avatar
Originally Posted by Rory McNeil View Post
And if it helps, we have a local racer with a 318 2 barrel that runs high 12s as a legal Q/Stocker.
Have you had a good look at it Rory?........
2009 V/SA Record Holder
Old 12-21-2012, 03:02 AM   #13
Rory McNeil
Phil, as you know , I am a Ford guy, but yes, I have looked Toms pink 318 2 barrel Callenger a few times at Mission. He ran it at the LODRS meet, and also ran it in our stickshift group a couple of times. Was I missing something? He was running 13.0s and 12.9s with it.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 12-21-2012, 03:13 AM   #14
J.R. Haddad
Liked 1,470 Times in 308 Posts
What type of fuel system would you run with the 2 barrel, fuel line
size, tank (or fuel cell) pick-up size, pressure, etc.?
J.R. Haddad is offline   Reply With Quote
Old 12-21-2012, 02:09 PM   #15
Paul Wong
Liked 419 Times in 85 Posts
Originally Posted by Sam Capizzi Jr View Post
I highly doubt that you can to run high 12s with a "legal" 318 2barrel. The 185 horsepower rating is about 10 hp to high. That's at legal P weight for a 1973 dart swinger at 3130 pounds
It can be done, but it is not easy. I got a legal 273 2 barrel 4 speed valiant in the 12's in Q/S that went through several NHRA teardowns and was looked at at Indy in 2005.
A good fuel system helps a lot with a carburetor with small volume like a mopar 2 barrel.
Paul Wong is offline   Reply With Quote
Old 12-21-2012, 02:20 PM   #16
Sam Capizzi Jr
Liked 43 Times in 9 Posts
Paul when you say good fuel system are you talking volume or pressure? And do you run the carter 2bbl
Sam Capizzi Jr. 1301
SS/AS 93 Dodge Daytona
R/SA 73 Dodge Dart
Sam Capizzi Jr is offline   Reply With Quote
Old 12-21-2012, 02:41 PM   #17
Paul Wong
Sal, its volume. Our little carburetors dont have much of a bowl and at 6000 plus they need everything they can get without the carb starving for fuel. Adding pressure fools with things as far as I can tell.
Old 12-21-2012, 03:15 PM   #18
Sam Capizzi Jr
That's very interesting....makes sense to me. My car runs 95 mph in 90 degrees or 35 degrees. I've tried diff fuel pressures from 6-12, no change. Stock needle and seat, stock jet size. When I go up in jet size the car drops right off ET and Mph
R/SA 73 Dodge Dart
Old 12-21-2012, 04:04 PM   #19
Duster 318
when i tried to change my jet size up it made the car run slower e.t. and mph was down. it is a carter also and the fuel pressure can make a big difference with mine.
