Any of you '67-'68 Camaro small block guys running these? Or are these not the lightest SBC spring that moroso makes? THanks and Merry Christmas to all!!
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 71 Times in 23 Posts
Brent, I use the 47150 it is a lighter spring then the 47140 and I have to cut 1 coil off.
Your motor is heavier then my 350, so I bet you will have to try the 47150 first without cutting anything off and see were it sets. If it sets to low you will have to go with the 47140. If it sets a little to high at first don't worry it will settle a inch or so.
Monte Howard 3209 STK, 3208 SS Last edited by Monte Howard; 12-22-2012 at 09:58 PM. |
#3 | |
Liked 93 Times in 52 Posts
I have the 47150 springs and did cut a coil off.
With an aluminum headed small block. Clark |
THanks!
