Old 12-29-2012, 11:31 AM   #11
Rory Christianson
Liked 9 Times in 6 Posts
Default Re: Tire size suggestions and brand
Thanks for all the replies and information that's what I was looking for
Yes sorry L88 with auto combination
Rory Christianson is offline   Reply With Quote
Old 12-29-2012, 12:33 PM   #12
Liked 1,874 Times in 422 Posts
Yep, that's the combination I thought you were going to run, the Hoosier package I suggested should be as fast, consistent, and affordable as any.
Old 12-29-2012, 12:35 PM   #13
Rory Christianson
Sounds great, thanks for the info Alan
Regards Rory
Old 12-29-2012, 01:06 PM   #14
I would strongly suggest you run Santhuff shocks on that, as the Corvette is known for violent wheelstands with big powr and good traction, due to the short wheelbase and good engine setback. You need the ultimate in front end control to prevent ugly things from happening. Specifically, you need to not have to "hit" the thing really hard to get it to hook and make the front end work. A lot of shocks have to be hit real hard to work, the Santhuffs do not, they work so smoothly that a 1.3 60' pass feels as soft as a 1.5 60' pass.
Old 12-29-2012, 01:17 PM   #15
Rory Christianson
Thanks again Alan
I will have a look at that for sure I was leaning towards afco or qa1 I have never used the others before
Old 12-29-2012, 02:23 PM   #16
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Qa-1 not good enough, not adj enough
Bob Pagano A/SA
Old 12-30-2012, 09:50 AM   #17
Liked 10,804 Times in 2,245 Posts
The last set of Goodyear radials I took off had 88 runs on them, the secret to long life is a short time in the water. On the Cuda the Goodyears are faster than the CO6 Hoosier. The front tires from Goodyear have very good longevity also.
Support at the track is very good, you can always find help if you need it from Goodyear. I believe Goodyear offers the best value and selection to the racer.
Old 12-30-2012, 11:18 AM   #18
Jim Fitzpatrick
I second Larry's assessment of the Goodyear Tires and support
Jim Fitzpatrick is offline   Reply With Quote
Old 12-30-2012, 11:55 AM   #19
Ed Wright
Ed Wright's Avatar
I agree, Goodyear support is second to none.
They hook at least as hard as anything I ever owned.
They are, however part of my slow down, or bracket mode. My MTs are about 5lbs each lighter, and .04 average slower in 1/4 mile. I think it is the weight difference, as about .03 of that shows up in 60'. Same lights with both sets, so they are a good thing to switch back & forth for class or heads-ups.
Ed Wright 4156 SS/JA
