Old 12-31-2012, 04:42 PM   #1
2021STK
Liked 17 Times in 14 Posts
Default G-body front brake upgrade, need help
Looking to improve over the stock front brakes on my '79 Malibu and wondered what you guys like from the aftermarket.
Happy New Year to everyone.
Thanks, Dave
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 01-01-2013, 10:23 AM   #2
Kent
Kent's Avatar
Default Re: G-body front brake upgrade, need help
Happy New Year Dave! Are you going stock eliminator racing?
Kent is offline   Reply With Quote
Old 01-01-2013, 12:02 PM   #3
Greg Turk
Greg Turk's Avatar
Liked 19 Times in 4 Posts
The kits from Strange or Moser which is the Wilwood I believe. are great choices, definitely run as fast as you can from the Aerospace stuff.
TURKMAN
4002 Stock, 4002 Super Stock
Greg Turk is offline   Reply With Quote
Old 01-01-2013, 12:26 PM   #4
Ed Wright
Ed Wright's Avatar
I have Aerospace brakes all the way around on mine. Fit great, don't drag, and stops very well. Been trouble free for five years. On what do you base a statement like that?
Ed Wright 4156 SS/JA
Old 01-01-2013, 02:46 PM   #5
Greg Turk
Greg Turk's Avatar
Glad you've had success, my first and last foray into Aerospace, not so good...kit ordered from them came with 2 different hubs, as in bearing races were like a half inch off, from one side to another, also while @ Indy 2006 the calipers , which were brand new, had problems,as in the inboard pistons would not retract enough to allow the pads to get off the rotors...after trips to midway ...while stockers are qualifying, I purchased new pads, and STRANGE calipers...which bolted up to the other guys brackets, bled brakes, pumped them up on jack stands, and to mine and Jim Hanigs amazement they released! And yes many attempts with washers were made to ensure the caliper was centered on the rotor...oh I made the qualifying hit...second to last pair...
Purchase what you'd like, believe me that's why STRANGE are on the Rear of my car!!! And the fronts have the same calipers from my ordeal(strange) with rotors, brackets , hardware from those other guys.
They were cheaper at first.....but cost me more in the long run.
I m sure this was an isolated incident, just a lack of Canadian know how on my part ....Right!!!!!
TURKMAN
Old 01-01-2013, 03:24 PM   #6
Greg Hill
Liked 279 Times in 68 Posts
I also have aerospace on both my car and Andrew's. they have been great. Light, don't drag, stop great, and hold on the starting line. They are also not that expensive. If cost is no object Lamb brakes are the very best.
Greg Hill 4171 STK
Old 01-01-2013, 08:07 PM   #7
2021STK
Hopefully going back into stock racing again with Malibu wagon. Took off last year due to catastrophoc engine failure, maybe I'll have enough parts by spring. Brakes were a small issue before, stopped fine just didn't hold great at the line so I'm going to upgrade.
Thanks everyone for the replies and input. Did any of you have to change the master cylinder to aftermarket? I have the original style manual MC and don't know if it will provide enough brake pressure & volume for aftermarket brakes. The pedal ratio is approx. 6:1 so I think that will be enough with 1" bore MC.
Dave Outten
2222 S/SS/SST/SG/HR
Old 01-01-2013, 08:25 PM   #8
Charley Downing
Liked 653 Times in 89 Posts
I put Mark Williams on our 1983 malibu wgn about 8 years ago with the Strange big bore master cylinder and have not had any problems with them in 8 years. We put Strange Brakes on our 1988 cultass with the Strange big bore master cylinder and they worked just as good for half the money. I would stay away from from Areospace brakes. I know 6 or so STK/SS racers in div 3 that have had rotors problems with them over the years. But that was 5 or so years ago, they might have there act together now.
Mike at MPR told us strange is your best bang for the money.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 01-01-2013, 09:33 PM   #9
2021STK
Thanks Charley!
MW would be great but I think Strange fits my budget better.
Dave Outten
2222 S/SS/SST/SG/HR
Old 01-01-2013, 11:39 PM   #10
Chad Rhodes
Same here on both cars
Chad Rhodes 2113 I/SA
