#31 |
Liked 816 Times in 215 Posts
What class would a 66 Corvette run with a 327/300 automatic ??
#32 | |
Liked 10 Times in 10 Posts
In 1966, the Corvette Coupe with the 327/300 HP would be classed in C/SA (9.50 - 10.59 Wt/Hp), based upon shipping weight. Along with the dominant 1962 Plymouth Sport Fury's 383/343 HP and Dodge Model #440 383/343 HP cars. 1966 NHRA C/SA Class Record = 12.92 Last edited by Paul Ceasrine; 01-03-2013 at 10:40 AM. |
#33 |
1965 Chevelle Malibu 4-Door Station Wagon
Not seen at the track in 1965 too much, not as a drag strip car anyway. * 283/195 HP............J/S.........(17.00 - 18.99 Wt/Hp) * 283/220 HP............H/S........(15.00 - 15.59 Wt/Hp) * 327/250 HP............F/S........(12.50 - 13.99 Wt/Hp) * 327/300 HP............C/S.......(10.60 - 11.29 Wt/Hp) * 327/350 HP............B/S.........(9.50 - 10.59 Wt/Hp) Even available with the 327/350 HP engine. How many B/Stock - 327/350 HP - 4-Speed - Station Wagons in 1965. ![]() Last edited by Paul Ceasrine; 01-04-2013 at 10:04 AM. |
#34 |
Liked 12 Times in 12 Posts
Paul, actually I've seen lots of '64 & '65 Chevelle/Malibu 2 door & 4 door station wagons that were used back then...here's a couple shots of one.
#35 |
A probably the the coolest ones ever built in my opinion...the 1965 SS396 Chevelle Z16.
#36 |
#38 |
The 1965 Chevelle 4-Door Station Wagons (#3420 lbs.) started to become popular
at the drag strips in 1968, when the NHRA re-set the class breaks. I believe the 327/300 HP 'automatic' cars fell nicely into (11.00 - 11.49 Wt/Hp) 1968. 1968.......G/SA 1969........H/SA 1970........ I/SA 1971.........I/SA Then the later NHRA Horsepower Changes * 283/220........235 HP.......SS/PA * 327/250........265 HP.......SS/NA * 327/300........280 HP.......SS/MA Last edited by Paul Ceasrine; 01-06-2013 at 11:03 AM. |
#39 |
How popular was the 1965 Chevelle 4-Door 327/250 HP Station Wagon in 1979.
A much desired combination, even after the NHRA re-factored them to 265 HP. Joe Kenney, the 1979 and 1980 Sportsnationals Super/Stock Winner. Last edited by Paul Ceasrine; 01-04-2013 at 04:18 PM. |
#40 |
1965 Chevelle Malibu SS396 'Z-16'
* Only 201 built 396/375 HP....Code #L-37 Engine Car Weight.......#3262 lbs. * Holley #3310 - 750 CFM Carburetor * Aluminum Dual-Plane High-Rise Intake * Rectangular Port Cylinder Heads * .461 / .500 Lift - Hydraulic Camshaft * 4-Bolt Main Block * 11.0 to 1 Forged Pistons * Forged Crankshaft * 4-Speed Manual Transmission (Only) * 12-Bolt Rear 1965 = A/Stock Though a desirable car for A/Stock in 1965, not so much in Stock Class in later years. Last edited by Paul Ceasrine; 01-06-2013 at 11:07 AM. |
