Old 01-06-2013, 01:07 PM   #1
Lonnie Cox
Default Need Gear Recommendation
You have all helped me with my stocker, I am getting closer to the index.But need more help.what I have is.
76 Camaro
350 cid
287 NHRA rated HP
350 turbo with 275 First
5.13 gears
Mickey Thompson ET Slicks 9x30
we ran a 12.80 @ 102 yesterday
shifting @ 7k
went thru the lights @ 6500
60ft 1.71
I have the Cal Tracs bars and springs
Thank You all I am happy I finally got in the 12's
Lonnie Cox is offline   Reply With Quote
Old 01-06-2013, 01:30 PM   #2
Liked 1,892 Times in 423 Posts
Default Re: Need Gear Recommendation
I'd consider going to a 2.52:1 low gear, and a 5.38:1 rear gear.
Old 01-06-2013, 02:15 PM   #3
Lonnie Cox
Alan I dont want to spend any money on this trans, would the 5.38 work for now I am thinking of a Pro trans later I am not sure I dont know what first gear ..
Old 01-06-2013, 04:26 PM   #4
Mark Lewis
Liked 208 Times in 45 Posts
what type of converter?
Looks like you ned about .15 just in 60'
5.38 won't help that much
Mark Lewis is offline   Reply With Quote
Old 01-06-2013, 04:39 PM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Need Gear Recommendation
Sounds like you're close, but try short shifting it about 6500 and seeing what happens. I usually don't turn a 327 that high through the gears. 5.38's to 5.13's isn't that different-5-7 % or so. You do need 60 foots in the 1.55-1.58 range, though. What class are you shooting for, and what index?
Old 01-06-2013, 04:47 PM   #6
Yeah, the 1-2 shift probably needs to be about 6200-6400, at most.
The 5.38 will help if you swap to a 2.52 low gear, what's going on here is you have way too much drop between 1st and 2nd, the car is not moving fast enough, and the RPM drops too far.
Old 01-06-2013, 04:58 PM   #7
jmcarter
jmcarter's Avatar
Liked 3,226 Times in 981 Posts
Think Mark is on it...converter or something else needs to be addressed. That 60 ft has to get better regardless of which index you're after.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-06-2013, 05:02 PM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Need Gear Recommendation
Carb tuning is a big factor as well!
Old 01-06-2013, 05:35 PM   #9
Lonnie Cox
Greg its is a 350 cid the class is I/SA 12.30 index,
Old 01-06-2013, 05:40 PM   #10
Lonnie Cox
converter is ATI 8inch Treemaster Salesman Charlie Plott
The 2 step was not hooked up, seems to do better when I flashed @ about 2800
