Old 01-08-2013, 12:34 PM   #61
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: 1965 New Cars and NHRA Classes
1965 Corvette
Std.....327/250 HP
L-75...327/300 HP
L-79...327/350 HP
L-76...327/365 HP
L-84...327/375 HP (Ram Jet 'Fuel Injected')
L-78...396/425 HP (Special High Performance)
New body additions, functional front fender louvers, and standard hood
with no depressions or moldings.
The 'Power-Glide' was only available with the 327/250 HP and 327/300 HP engine combinations.
The L-78 Option, required the special 'power blister' Bubble hood, with the side
fresh-air inlet vents.
Optional, Side Exhaust Pipes
Old 01-08-2013, 01:18 PM   #62
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
1965
The new 65' Ford Mustang Fastback with the 289/271 HP 'HiPo'....'K-Code'
In 1965, classed in C/Stock (10.60 - 11.29 Wt/Hp)
1968 Photo....Classed in F/Stock (10.50 - 10.99 Wt/Hp)
This one, equipped with a Doug Nash prepared engine, and 5.67 Gears. Could run 12.80's @ 111 MPH.
F/Stock NHRA Class Record in June 1968 = 12.72
Isn't this a 1966 Mustang? Grill is all bars. 1965 should be horse in the middle and a single bar on each side. 1966 also had the horse.
Steve Jackson
Old 01-08-2013, 01:26 PM   #63
Paul Ceasrine
Mr. Cyclone Fe,,,
You're the Ford man,,,,,,,
Photo is from 1968, when both the 65' and 66'......289/271 'HiPo' Mustangs were classed in F/Stock.
The site I copied this from stated that Bill Salveta (Owner) was running a 65' 'HiPo Pony'.
If you look closely, it looks like there might have been a 'Horse Medallion' in the grille-center at one time.
Old 01-08-2013, 02:20 PM   #64
Paul Ceasrine
In 1965,
The higher Horsepower Corvette's could not run in Stock Class, and had to opt over to the Stock Sports Car Class
L-78......396/425 HP.....C/SP
L-84......327/375 HP.....D/SP
L-76......327/365 HP.....D/SP
L-79......327/350 HP.....E/SP
Old 01-09-2013, 10:36 AM   #65
Paul Ceasrine
1965 Oldsmobile 4-4-2 (400/345 HP)
B/Stock (9.50 - 10.59 Wt/Hp)
Old 01-09-2013, 04:55 PM   #66
Paul Ceasrine
1965 Chevelle Malibu 4-door , with a 283/220 HP
In 1965 they had a perfect fit into G/SA (14.00 - 14.99 Wt/Hp)
1969 Photo (Classed in M/SA)
Old 01-10-2013, 04:07 PM   #67
Paul Ceasrine
1965 Pontiac Catalina 2 + 2
A 'monster' at 3800+ lbs.
* 421/338 HP...................................D/S or D/SA
* 421/356 HP...................................C/S or C/SA
* 421/376 HP (H.O. Tri-Power)......B/S or B/SA
Old 01-10-2013, 08:23 PM   #68
Paul Ceasrine
Another Oldsmobile 4-4-2
400/345 HP = B/SA (9.50 - 10.59 Wt/Hp)
Old 01-10-2013, 09:31 PM   #69
Hemi Moose
Liked 12 Times in 12 Posts
New Pontiac's for 1965...
Old 01-10-2013, 10:17 PM   #70
Hemi Moose
Looks like they swapped out the front bumper on this old Goat...
