Old 01-14-2013, 01:37 PM   #1
Jeremy
Default Stock class racing seats
I was just wondering if anyone has any thoughts on the Jaz Polyethylene racing seats? Also do you think are the Summit/Jegs brand the same as the Jaz brand?
Thanks Jerry
Jeremy is offline   Reply With Quote
Old 01-14-2013, 03:26 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Stock class racing seats
You would be better off in the long run with an aluminum seat. The plastic seats have molded-in threads that can pull-out over time. A friend has one of those in a bracket car and after two years, the threads are already starting to pull-out of the seat, and he's not a real heavy fellow either. My .02.
Jim Kaekel 3836 STK
Old 01-14-2013, 09:58 PM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
x-s2 on the aluminum seats. leave the poly seats to the grade school cafeteria's
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-15-2013, 02:13 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Stock class racing seats
Chad should be here any second to scold you.
2009 V/SA Record Holder
Old 01-18-2013, 09:40 AM   #5
Chad Rhodes
poly seats belong in dune buggies ( or Phillip's car). As much as I disliked being required to run seats that in some cases are over 50 years old, installing a plastic one with molded in "inserts" seems even worse. There Phillip, are you happy now. Wasn't even going to reply till i read your reply.
Chad Rhodes 2113 I/SA
Old 01-18-2013, 11:42 AM   #6
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I will keep my bench.....
Bob Bender 144 O/SA
Bob Bender is online now   Reply With Quote
Old 01-18-2013, 12:38 PM   #7
You daredevil, you
Old 01-18-2013, 12:48 PM   #8
Ed Wright
Ed Wright's Avatar
Mine have through bolts. I can't imagine anybody trusting threaded bolt holes I. Their seats, no matter what they are made of.
Ed Wright 4156 SS/JA
Old 01-18-2013, 01:53 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Thanks Jerry
I think I have the summit seats. I have the driver side thru bolted to the floor and cage. Nice comfortable seat. Light weight too.
Mike Pearson 2485 SS
Old 01-18-2013, 07:40 PM   #10
SuperStockDodge
SuperStockDodge's Avatar
Thumbs up Bob!!!
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
