Old 01-26-2013, 10:36 PM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default 2004 Jerico DR4 with 2.83 1st gear
After seeing that a new Jerico is going to cost me $4,700.00, it looks like I won't be able to keep this one !
Has about 60 runs on it, with a 530 horse engine, and a relentlessly slipping clutch.
No issues at all... works perfectly. Simply not enough torque multiplication for my heavy car.
2.83, 1.94. 1.33 ratios.
Transmission alone... need $2,000, firm.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-27-2013, 03:27 AM   #2
Rory McNeil
Default Re: 2004 Jerico DR4 with 2.83 1st gear
Aubrey, rather than selling your current Jerico DR4 and buying a DR4-4, just to get better gearing, why not just regear you trans? Before I bought my 2nd Jerico, I "borrowed" the Jerico from my bracket car, for my Mustang Stocker, which had a 2.93 low gear, and my buddy changed the 2 main drive gears, which gave me a 3.19 low, and cost about $300.00 for parts. It also changed the 2nd and 3rd ratios a bit, but it worked fine for my car.
NHRA 6390 STK
M/S 85 Mustang
Old 01-27-2013, 11:35 AM   #3
Aubrey N Bruneau
A few reasons, Rory...
I 'm looking at making quite a change, possibly as much as 3.17. The engine has an unusually broad torque curve, so a wide spread between gears, would work fine. This would mean changing at least 3 gear sets.
Another reason, is that I'm paranoid ! This transmission works flawlessly as is. I'd be worried about "disturbing" it, and having something that maybe doesn't work perfectlly.
My own mistake. I simply ordered the wrong gear ratios for my car.
For a light car.... it's perfect.
BTW, I should mention... This particular transmission uses GM 26 spline input, with the large GM M22 / TH 400 size output. The case and configuration replaces a regular GM Muncie M22 or B/W Super T10.
Old 01-27-2013, 05:35 PM   #4
Mark Ugrich
Liked 71 Times in 38 Posts
[QUOTE= I should mention... This particular transmission uses GM 26 spline input, with the large GM M22 / TH 400 size output. The case and configuration replaces a regular GM Muncie M22 or B/W Super T10.[/QUOTE]
Any idea what would need to be changed to configure the trans to fit a 1965 Mustang? Are the tailhousing and output shaft length the same?
Old 01-27-2013, 08:50 PM   #5
Aubrey N Bruneau
No idea, Mark.
Bolts in as a standard Chevrolet, so it may not be right for a Ford !
Old 01-27-2013, 09:18 PM   #6
vettenights
how heavy is your car mine is 3400 with a 4.56 rear gear thinking i need maybe a 3.08 or so was running a 2.88 t10
vettenights is offline   Reply With Quote
Old 01-27-2013, 09:22 PM   #7
Mark Ugrich
I know Ford used T-10's in some Mustangs.I'll check with Jerico next week.Is there a part number or reference number I could give them to narrow it down some? Thanks,Mark
Old 01-27-2013, 09:41 PM   #8
Aubrey N Bruneau
I'm at 3640 with a 5.13
Old 02-08-2013, 10:39 AM   #9
mcashman
Liked 6 Times in 3 Posts
Do you stil heve trans for sale?
mcashman is offline   Reply With Quote
Old 02-08-2013, 10:55 AM   #10
Aubrey N Bruneau
Of course !
Don't want to commit to the $4700.00 one, until this one is sold.
Search this Thread:
Advanced Search
