Is .040 ok or should i put a thicker head gasket on it. zero deck motor.
Liked 510 Times in 117 Posts
Type of engine? Piston to wall clearance? Class?
68 Chevy11 327 F/S |
Piston weight ?
RPM ? Stroke length ? Steel or aluminum rod ? ! ! With 720 gram bare piston, I run .036" , to 7400... no issue.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Liked 54 Times in 18 Posts
We ran .050 on a 68 Camaro Z/28 stocker back in the early 80s. Those were the stock piston rule days. We wouldnt have if we could have cut the valve reliefs
Liked 22 Times in 22 Posts
Plenty with steel rods, no matter the rpm.
don,t have one |
I don't have all the specs,but it's a 540 mopar with 4.500 bore and 4.250 stroke and uses a 7.100 steel oliver i-beam that i spin to almost 8000 rpm.
Since this is obviously not a Stocker engine, why not cut deeper eyebrows for piece of mind?
40 is fine. For piston to head, that is.
don,t have one |
Sorry, I misread it too. We ran .035, I wouldnt run less then .030 but some do
