#11 | |
Liked 12 Times in 6 Posts
Adam good to hear it is worth power. Scott |
#12 |
Liked 249 Times in 48 Posts
If this is all legal I've learned something new.
#13 |
Liked 96 Times in 23 Posts
NHRA pours an outer runner to check cc`s on a Pontiac head.
It`s okay to fill the heat crossover but you can`t do any blending in the exhaust bowl on a Stocker head. On a bracket head my buddy who does heads for a living will over fill the heat crossover in the exhaust bowl so he can blend all that in when he ports the head. Not legal in Stock.
Adam Strang 1018 STK |
#14 | |
Liked 68 Times in 41 Posts
page xv under "HOW TO USE THIS RULEBOOK" in the rule book On the other hand, as to performance equipment, it is the general rule that unless optional performance equipment or performance-related modification is specifically permitted by this Rulebook, it is prohibited. All model, engine, or equipment changes or modifications not specifically addressed in this Rulebook must be submitted in writing to NHRA for consideration prior to competition. Approval will be granted or denied in NHRA’s sole and absolute discretion. The applicant will be notified of approval or rejection in writing from NHRA headquarters in Glendora, Calif. as I read it "Blocking passage down in valve pocket prohibited."I have not seen any where in the book that says "I was under the impression" lol
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 01-29-2013 at 02:17 PM. |
#15 | |
Liked 327 Times in 121 Posts
#16 |
Considering that all the accepted Edelbrock aluminum heads that I`ve seen have no crossover provision at all, thus no "cave" in the port, wouldn`t it be nice if NHRA allowed factory heads be completely filled too?
#17 | |
On Stockers, I place a cotton ball, saturated with plaster of paris into the exh. hole from the port side. I push it in about 3/16ths so there is no question about it being in the port. This does not hurt the flow ,I have been told .I then fill it right up from the intake side, and then grind off excess. On bracket engines , I fill from the port side ..in one side ,until it comes out the other port, then grind and smooth, as others have stated. It really helps to put about a 1/16 th air bleed hole in your block off plate. I have been using aluminum and a home made ladle ,and a cutting torch. I will look into the zinc deal. Thanks
#18 |
Liked 101 Times in 34 Posts
Thanks to all that replied, Ron.
#19 |
Liked 56 Times in 27 Posts
Ron,
You have a PM ........
Dave Ribeiro 1033 STK |
#20 |
Adam Strang, you have a pm.
