Old 01-31-2013, 04:29 PM   #1
bill dedman
Liked 6 Times in 4 Posts
Default O-Ring grooves in head...
Can anybody recommend a machine shop trhat could cut O-Ring groovrs into an inline, six-cylinder cast iron head in my area (centrtal Arkansas)? This thing weighs 84 pounds and I don't really want to have to pay a king's ransom in shipping on it if I can avoid it.
Any help will be appreciated.
Bill, in Conway, Arkansas
Bill
bill dedman is offline   Reply With Quote
Old 01-31-2013, 07:44 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: O-Ring grooves in head...
Isky makes an affordable tool for the do-it-yourselfer. It cuts the groove in the block using the bore as a guide. Otherwise any shop should be able to handle it either to the block or head in your area. Not a complicated process.
Jeff Lee 7494 D/S '70 AMX
Old 02-01-2013, 01:30 AM   #3
69Cobra
Liked 2 Times in 2 Posts
PM Jeff Colvert on the forum here. I'm sure he could hook you up.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 02-01-2013, 05:35 AM   #4
bad440
bad440's Avatar
what happened bill?did it pop a gasket already?
bad440 is offline   Reply With Quote
Old 02-01-2013, 09:14 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Bill -
Call Johnny Case at Case Machine and ask him. He knows lots of machine shop people around the state. Also, somebody in LR has an Isky tool because the drag boat people used to do that a lot on aluminum head BBCs. Call Leonard at Auto Sports Center 501-375-7223.
Dwight Southerland is online now   Reply With Quote
Old 02-01-2013, 12:37 PM   #6
Run to Rund
Liked 55 Times in 28 Posts
It seems the biggest problem comes when a machine shop isn't careful enough to keep the groove depth uniform.
Old 02-02-2013, 09:04 AM   #7
bill dedman
Jeff, the block is already installed in the car. I just want to do rthe head.
Bill
Old 02-02-2013, 09:19 AM   #8
bill dedman
Thanks, Cobra; I need to talk to him, anyway...
Bill
Old 02-02-2013, 09:24 AM   #9
bill dedman
Nope; just looking down the road at the time when I have 25+-pounds of boost and that is a real possibility.
I should have thought about that before the block went into the engine bay...
20/20 hindsight...
Bill
Old 02-02-2013, 09:29 AM   #10
bill dedman
I'll keep that in mind; thanks for the tip!!!
Bill
