Old 02-08-2013, 04:35 PM   #11
Dennis424C
Dennis424C's Avatar
Liked 2 Times in 2 Posts
Default Re: Scaling HELP !!!
It was 100#'s heavy on the left with no pre-load and me (driver) in it. I understand how the pre-load works and I am trying to get the scaling correct with the bars loose or no pre-load. I will check all the spring perch and mounts again but I think it just might be a weight issue. If all checks out I will add 30lbs to the right rear and report back. Thanks for the suggestions
Dennis "The Menace" Clark
424C Pro E/T
424C S/ST H/R S/G
Dennis424C is offline   Reply With Quote
Old 02-09-2013, 08:45 PM   #12
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
Are the rear brakes disk or drum? Make sure the brakes are in good shape or this could steer the car with the front in the air. Have someone film it from the rear and study the car that way too. I would also start with making sure the rear is square in the car.
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
Old 02-10-2013, 11:07 AM   #13
Liked 10,850 Times in 2,254 Posts
Had this happen to me. Right rear shock at full extension was .75" shorter than left rear shock. At the hit, rear would separate enough to pick up right rear tire causing car to turn right. This would only happen in very good weather or in a heads up race. We were lucky to find the problem with the help of the local track photographer. We only had to fix a hole in the oil pan and had to fix two front wheels on the Cuda.
Old 02-10-2013, 06:04 PM   #14
rod
Liked 20 Times in 15 Posts
check the axle housing to verify that it is, in fact, straight and true. this must be toe-in and camber. a lot of cars have bent housing and the driver does not realize it. especially 12 bolts, as they are weak, being three piece units. even when welding the tubes to the center, they bend. I just checked a 9" Ford and it was out almost 3/8" toe and a little less than 1`/4" camber. makes you wonder.
next make sure there is no rear brake drag [regardless of type].
Rod in AZ
rod is offline   Reply With Quote
