Old 02-18-2013, 01:18 AM   #21
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: Mike Cotten you are the MAN!
Video here, about the 16 min mark....
[ame="http://www.youtube.com/watch?v=VKBIc2hWGNM"]2013 NHRA Winternationals Finals - YouTube[/ame]
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 02-18-2013, 02:14 AM   #22
Tom Moock
Liked 10 Times in 6 Posts
I watch the replay on Espn 3 about 10 times you can see mike car move to light the stage light, but i didn`t see movement on Defrank car,maybe he was not stage deep enuff? They had 3 or 4 different camera angle`s on espn 3,if nhra wanted to watch replays? the replay video is better on espn 3 than the you tube video. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 02-18-2013, 05:13 AM   #23
Jimmy70RSSS
Liked 2 Times in 1 Post
Worked at Suffolk the last year they were running and had a similar instance. The guy in the right lane staged so shallow that the relay in the old Chrondex box was buzzing......off on off on. The stage light was on but was flickering so fast it appeared to stay evenly lit. I waiting a little longer than usual and as soon as I activated the tree it was an instant red. That's an old system and I'm not sure how large a diameter the beam is but when we setup every weekend the receiving end had a very small hole in it and it would be a fluke for a flash to trigger it. How about going to a different light source.....infrared beam or something that sunlight or a common camera flash won't trigger.
Jimmy70RSSS is offline   Reply With Quote
Old 02-18-2013, 09:15 AM   #24
Ed Wright
Ed Wright's Avatar
I have a dumb question (go easy, I'm old) where do you find ESPN3? Cox cable has more than one ESPN, we have 2 but not 3.
Btw, I staged too shallow once, but I saw the stage light flicker about the time the tree started to come down. I knew that one was on me.
Ed Wright 4156 SS/JA
Old 02-18-2013, 09:31 AM   #25
Bill Mitchell
Liked 26 Times in 4 Posts
Not all Internet service providers have ESPN3-I have it at home thru Cablecom but different provider at business does not.
Bill Mitchell 5540
Bill Mitchell is offline   Reply With Quote
Old 02-18-2013, 09:39 AM   #26
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Talking Re: Mike Cotten you are the MAN!
Congratulations MIKE and Paula, great pic on dragracecentral ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 02-18-2013, 09:41 AM   #27
Ed Wright
Ed Wright's Avatar
So, it is on the Internet, not TV?
Old 02-18-2013, 09:50 AM   #28
Bill Mitchell
On internet-search for ESPN3 or ESPNwatch then when you try to accsess programming it will inform you if your provider has it.
Bill Mitchell 5540
Old 02-18-2013, 10:16 AM   #29
Scott Dugdale
Liked 57 Times in 20 Posts
Congratulations to Mike Cotten and Jimmy Defrank to reach the final. It's unfortunate that the outcome of a possible timing glitch could cause a outcome like this in a final round of a National Event. There has been multiple incidents at Pomona regarding this same problem. Recently with Don Mason and another incident at the Summit Finals with a local racer from Minnesota. This same thing occurred to myself at a local racetrack in the Division 5 area in 2009. I happened to be the faster car and the stage bulb was flickering when it was then indicated I was fully staged. The tree came down on their side and when my tree started the red light occurred without the car moving. I was told that the car was shallow staged enough to remove the tire from the stage beam. This track doesn't have stage lock and could occur if the car is shallow staged. The video that I seen of the final at Pomona is identical to the elimination round that occurred to me in 2009.
I also attached a recent article that occurred last year to Jack Beckman during a Semi Final.
http://www.competitionplus.com/drag-...-not-red-light
Is stage lock setup at all National Events?
Scott Dugdale
5317 I/S
Scott Dugdale is offline   Reply With Quote
Old 02-18-2013, 10:30 AM   #30
Ed Wright
Ed Wright's Avatar
If it flickers, you are not in far enough.
