Old 10-31-2009, 09:00 AM   #11
Larry Fulton
Larry Fulton's Avatar
Default Re: 1970 nova ??????'S
Originally Posted by Todd Bailey View Post
I'm in the same boat here. How much do the tech guys lean on you to have the correct lights/bumpers for the year you are claiming?
From what we've seen pass tech lately, Not Enough!
Larry Fulton
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 10-31-2009, 11:54 AM   #12
Bobby Zlatkin
Bobby Zlatkin's Avatar
That's funny! Dip your toe in the water and run .6 to .7 under. I think you will have to at least get in up to your waist to do that.
I think claiming as a '71-'72 would be the best way to go. More favorable HP rating.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 10-31-2009, 01:05 PM   #13
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Yea you don't just run .6 or .7 under with one of those combos.... now then if you would want to run a 230 6 cyl....... that may not brake the bank
Old 10-31-2009, 01:38 PM   #14
Joe DeMarzo
Liked 121 Times in 11 Posts
I have a 70 nova which i ran for 2 years in A/SA & B/SA with the 402 combination. Ran -1.2 under and won a race in A/SA. Lots of fun to drive. Currently running it as a 72 350/200hp combination. Car runs -1.18 under first year out and won a race in G/SA. It is a good combination and a lot less expensive then the 402. I repeat a lot less expensive than the 402. Maintenance is a lot less and the parts are more readily available for the small block. You can get 150 runs out of a small block not the big block. Did I mention the small block is a lot less expensive than the big block. Call me if you want to talk (845-216-8027), I will give you the pro's and con's. All depends on your time and money. -1.0 is easy with either combo. Find out the killer cars in A/B or F/G/H in your division, In Division 1 everyone is killer...........
Joe DeMarzo 1317 STK
Old 11-02-2009, 09:25 AM   #15
ron mattson
Liked 69 Times in 32 Posts
the 1972 combo is easier to make run than the 1970/300 but to have a killer you will
still have to spend the cash,just a little less..i have both combos and can give you the
highs and lows of each if interested. 218-878-3456 ron mattson
ron mattson is offline   Reply With Quote
Old 02-17-2013, 11:02 PM   #16
Green2x85
Originally Posted by Bobby Zlatkin View Post
There is only one 1970 combination that will put you in G or H, a 300/350.
Claim it as a 1969 and add the 255/350 to that list.
However, to be competitive in either, you will have to break the bank unless you have a big bank.
Or, unless you buy one already built starting at approx. $17,000. More for a better one.
Just curious if your talking $17k for a motor or a decent car???
Green2x85 is offline   Reply With Quote
Old 02-18-2013, 02:23 AM   #17
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Gary Waldo's stick car is for sale.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-18-2013, 10:01 AM   #18
FLEMING
Liked 55 Times in 26 Posts
Red face Re: 1970 nova ??????'S
I was looking at making my nova into a stocker (pretty much already is other than motor).. I had 2 good engine guys qoute me a motor Both were $12,500 for a good piece... That I was told would have to be ran on kill to run .8 to .9 under in H/J/K That is a BAD place to be I have found out..
So I have came to the conclusion that I have to either get a different car/class combo or not race stock...
I have always wanted to race stock eliminator but I am not gonna spend 12 grand on a motor to do so, I race for fun but I want to be able to have some return on my investment.. so spending 3-4k on a bracket motor and I can more than pay for that in a year racing local..
Maybe someday if the powerball numbers hit..
FLEMING is offline   Reply With Quote
Old 02-18-2013, 11:26 AM   #19
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Fleming don't give up! Shop the classified section on this site, make contact with the relative sellers. They have all been down the same road and are in most cases, full of advice. There are several carburetors for sale on here now, and might save you some money. The best cam and lifters,valves, valve springs, retainers and push rods are what is going to cost the most (new). Roller rockers are legal and not having to worry about stock style rocker failure now, has changed things. If you buy your pistons from say CP they will supply a ring package that will put you in the program, legal rods are available from Summit or Jegs. Talk to some of the local Stocker guys to put you in the direction of "their" cylinder head guy. Make sure you have all your casting number cores correct for the class. Have the engine prepared and assembled by a local reputable shop and explain what you are doing, they might be interested in giving you a bit of a break on the labor and the right guy will work with you. A lot is in the correct preparation and assembly of what parts you have, you'd be surprised what will work and how long it lasts. You might not be the furthest under but you can be part of class and bracket race it too. You can progress your way to that $12500.00 piece. How much can you do yourself? That is where you can save. Hope this helps...MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 02-18-2013, 03:36 PM   #20
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I don't know if it makes you feel any better Steve,but I have been trying to put together a NHRA combo for over 10 years and all I have to pay for is parts cause as you know I do all my own work. I have 90% of short block stuff maybe this year hopefully.
Mike Taylor 3601
