Old 02-19-2013, 10:46 PM   #1
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default LS 1 engine removal tool
I have heard of a tool that makes engine removal very easy in the Camaro/Firebird. Who makes it and what is the cost. Is the tool different for the LT1? I am considering putting a LS1 in my '97 Trans Am. The LT1 has been nothing but trouble.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 02-19-2013, 10:54 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: LS 1 engine removal tool
What kind of tool are you talking about Richard?
I put my car up on my 2 post lift, and take my LT1 out the bottom.
I would do an LS1 the same way.
Ed Wright 4156 SS/JA
Old 02-19-2013, 11:16 PM   #3
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
http://tpis.com/parts/view/67
LS1Racer is offline   Reply With Quote
Old 02-19-2013, 11:23 PM   #4
KRatcliff
Liked 534 Times in 143 Posts
I have dropped it out the bottom and pulled it from the top with a Happy Hooker. I have yet to pull it out the front, but it looks like a quicker option.
[ame="http://www.youtube.com/watch?v=feeFmQ8RPcU"]http://www.youtube.com/watch?v=feeFmQ8RPcU[/ame]
KRatcliff is offline   Reply With Quote
Old 02-20-2013, 11:53 AM   #5
Kegracing
Kyle,
I dont think Pete will let you get away with that....
Kegracing is offline   Reply With Quote
Old 02-20-2013, 11:56 AM   #6
KRatcliff
You are right, but I did send this video to Gary Emmons before I worked on his car. Don't know why he acted so fidgety.
Old 02-20-2013, 12:19 PM   #7
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I have a "Happy Hooker" and used it with my LT1. It uses the little metric bolts that hold the fuel rails on, scary, but worked well. When I changed to the LS1, I would put the engine in with the intake off. There was no way to do it without smashing the plastic intake. Dyno
Old 02-20-2013, 07:22 PM   #8
vettekid1975
i've pulled ls1's out of fbodys multiple times. i found it easiest coming out right through the top. used 4 valley cover bolts and pulled the trans/engine as one piece. the angle is very steep but it cake with 2 people
vettekid1975 is offline   Reply With Quote
Old 02-20-2013, 09:07 PM   #9
Richard Grant
the Happy Hooker looks like the tool that I had seen and heard about. I had heard that without it, you had to pull the motor from the bottom and without a lift that didn't seem like a viable option. Thanks guys.
Old 02-21-2013, 08:14 AM   #10
joelster
It's faster to pull it out the bottom. I helped a friend of mine who is very knowledgeable with LT1 cars, pull one. From start to finish we had the engine out in under 2 hours and on a roller table. There are so many annoying bolts that you don't need to disconnect when you pull the engine from the bottom. All of the header bolts stay, all of the transmission bolts stay. You basically remove the 6 k-member bolts, the 8 shock tower bolts, all of the radiator hoses, fuel lines, crossmember, driveshaft, wiring harness plug, throttle cable, etc.
The only messy part is that you have to disconnect the front brake lines, but everything is much more accessable.
joelster is offline   Reply With Quote
