Old 02-21-2013, 09:02 AM   #11
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Default Re: LS 1 engine removal tool
If its a street car I highly recommend coming out the bottom. On a race car top is no problem.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 02-21-2013, 12:16 PM   #12
KRatcliff
Liked 534 Times in 143 Posts
Originally Posted by Richard Grant View Post
the Happy Hooker looks like the tool that I had seen and heard about. I had heard that without it, you had to pull the motor from the bottom and without a lift that didn't seem like a viable option. Thanks guys.
This should work better than the Happy Hooker for an LS1.
http://carshop.carshopinc.com/produc...138470/CSP2397
KRatcliff is offline   Reply With Quote
Old 02-22-2013, 08:01 AM   #13
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
On street car w/heater etc. I think out the bottom is better I believe,I could have on floor before I could get header bolts,if I could even get them out.
Mike Taylor 3601
Old 02-22-2013, 08:29 AM   #14
Ed Wright
Ed Wright's Avatar
Since I have an aversion to crawling around in the floor, (I'm old and would have to get back up) I use a roll around hydraulic table for the engine & Trans to sit on, and my lift, I can have it out almost as fast as I could get the headers out. The headers go on & come off sitting on that table.
If I'm changing cams, headers, or pulling heads I raise the car off the engine & Trans sitting on that table (aka take it out the bottom) and just work on it right there. When done I just let the car back down & and bolt up the motor plate, cross member & put the drive shaft back in. The ECU harness & two fuel lines had to come off either way. I find that easier than bending over the fenders. But, as I mentioned, I'm old.
Ed Wright 4156 SS/JA
Old 02-22-2013, 07:02 PM   #15
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
Smile Re: LS 1 engine removal tool
I have the happy hooker tool but I would agree on a street car it's easier coming out the bottom. I just pulled the engine out of my street Camaro. I don't have a lift and have a low ceiling so I spent an extra hour pulling the front bumper cover. I believe it took me about 4 1/2 hours but then again I am old. It still seemed much easier than pulling it from the top. Sure would be nice to have a lift!!
LS1Racer is offline   Reply With Quote
Old 02-22-2013, 09:41 PM   #16
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
On second thought, it does seem easier to remove it from the bottom. It seemed in the beginning that there was no way it could be easier but looking at the engine in the bay and knowing everything is difficult to access, I agree it would be easier from the bottom. It's like other situations where until you tackle something, one way just appears to be more difficult but after a through study another way is not as difficult as first considered. Thanks everyone for helping me see things from a different perspective.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
