Old 03-07-2013, 05:46 PM   #1
mopar jeff
mopar jeff's Avatar
Default Injector question
So I was thinking of upgrading the injectors on my LT1 powered Stocker, but $600 is a bit pricey. Is there a problem with just picking up a used set off Ebay for around $100, and having them cleaned if necessary?
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 03-07-2013, 06:05 PM   #2
Mike Savelle
Liked 7 Times in 5 Posts
Smile Re: Injector question
you have a PM
Mike Savelle is offline   Reply With Quote
Old 03-07-2013, 07:24 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: Injector question
Jegs has ACCEL injectors for something like $375.00. Thy are not Bosch injectors, which are as good as they come. 30lbs is plenty big enough.
Ed Wright 4156 SS/JA
Old 03-07-2013, 07:35 PM   #4
mopar jeff
mopar jeff's Avatar
Ed I would like to do the Bosch ones, just so I don't leave anything to chance. Just wondering if buying them used is acceptable, or do they have a life span? Thanks.
Jeff Interlicchia
Old 03-07-2013, 07:54 PM   #5
Ed Wright
Ed Wright's Avatar
Jeff, it's nothing to see them go a couple hundred thousand miles. I would have them cleaned and flow tested for sure. Bench-top machines clean, flow test and you can see the spray patterns. Well worth it. I have mine done every winter just to be safe.
If they came from a race car they couldn't 't have many actual miles on them. I would still have them cleaned & tested to make sure.
Old 03-07-2013, 08:18 PM   #6
mopar jeff
mopar jeff's Avatar
I would imagine I will end up with a set from a street car, but maybe someone on here has a set for sale.
Jeff Interlicchia
Old 03-07-2013, 09:19 PM   #7
KRatcliff
Liked 534 Times in 143 Posts
The Venom 30lb injectors that you can get new off Ebay are $299.99 and would be darn close to the Ford Racing injectors as far as your needs. I think they flow slightly more than the Ford's according to Jeff Warren, but it wouldn't cause you any problems.
KRatcliff is offline   Reply With Quote
Old 03-07-2013, 10:35 PM   #8
Ed Wright
Ed Wright's Avatar
[QUOTE=KRatcliff;372313]The Venom 30lb injectors that you can get new off Ebay are $299.99 and would be darn close to the Ford Racing injectors as far as your needs. I think they flow slightly more than the Ford's according to Jeff Warren, but it wouldn't cause you any problems.[/]
I would avoid those. Very high failure rates, and too often don't flow as rated. I have seen so many problems with those I now refuse to tune a car with them. Stick with Bosch or Lucus if your not going to use the originals.
Old 03-08-2013, 01:00 PM   #9
mopar jeff
mopar jeff's Avatar
That is about 1/2 price Kyle, but maybe I should take my chance on a used set of Bosch, which will even be half of the Venoms.
Jeff Interlicchia
Old 03-08-2013, 06:21 PM   #10
KRatcliff
I prefer the Ford Racing/Bosch if you can find them, but that is the problem. We haven't had any problems with the Venoms, but YMMV.
