Old 03-09-2013, 01:53 AM   #11
Tom Moock
Liked 10 Times in 6 Posts
Default Re: weight question
Duster 318, N/SA 2850, O/SA 2945, P/SA 3130 with driver. 318 at 185 hp. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 03-09-2013, 11:22 AM   #12
George Mirza
I've been racing a Duster for years, and I can't see how you could get one with a 318 in it under 3000 lbs. with driver in legal stocker trim. Duster 318 I would shoot for O, but if you don't remove everything possible and put light weight brakes etc, you'll be closer to P weight.
If the car has frame connectors,a roll bar and 8 3/4 rear it will most likely be between 3000- 3100 lbs without the driver.
Good luck,
George
George Mirza is offline   Reply With Quote
Old 03-09-2013, 11:58 AM   #13
Duster 318
i havent had the car weighed yet im hoping its closer to N/SA but i dont have a problem running O either. it has a roll bar in it with a bar underneath to. tom i thought the hp was 230?
Duster 318 is offline   Reply With Quote
Old 03-09-2013, 01:11 PM   #14
Hans Olsson
Hans Olsson's Avatar
OEM hp 230
NHRA hp 185
Hans Olsson is offline   Reply With Quote
Old 03-09-2013, 01:48 PM   #15
bdixon
Liked 15 Times in 7 Posts
Duster 318....I have a72 duster and i raced all last year in e/sa min wt 3100 and i carry way more in the drivers seat than the 170 std....haha good luck to you bryan stk511
bdixon is offline   Reply With Quote
Old 03-09-2013, 02:32 PM   #16
Duster 318
im thinking it will weigh about 3100. im 17 years old and only weigh about 120 pounds so that will help me out some haha
Old 03-09-2013, 05:22 PM   #17
Tom Moock
Duster 318, 230hp is the factory hp, nhra rated at 185hp. Tom
Tom Moock 5704 STK
Old 03-09-2013, 06:07 PM   #18
Duster 318
thank you for all the help you have all been very helpful
Old 04-01-2013, 07:24 PM   #19
Duster 318
since the minimum weight for n/sa is 2850 and say the car weighs 3100? can i still run N or do i have to go up to O or P?
Old 04-01-2013, 10:12 PM   #20
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Driver weight of 170lbs is automatically added to factor weight so even if you weigh 120, you'll have to put 50 more pounds of ballast in car the make up the difference.
On your weight/class question, you cannot exceed max weight that would put you into next class up so your answer is yes, you have to go up to O or P.
Bob Don 128 SS
